02-24-2015, 07:15 PM | #1 |
Rep 91
ECS Differential Service Kit
My '08 m3 is now due for the rear differential fluid flush. I was on the ECS Tuning website and noticed they have a Differential Service Kit for our cars.
http://www.ecstuning.com/BMW-E90-M3-...ain/ES2602524/ At $70.34, it is significantly less $$ than the OEM fluid at $48.17/.5L. The kit uses Castrol Syntrax SAF-XJ 75w140. Has anyone used this or could make recommendations on using this kit? Thanks in advance! |
02-25-2015, 11:00 AM | #2 |
Rep 230
That's a significantly lower price than what I usually use: http://www.ecstuning.com/BMW-E93-M3-...ain/ES1895208/.
But then again, it's "Genuine BMW" compared to the substitute you indicated.
'04 E46, '08 E93, '16 F22 M235i, '17 i01 i3
02-25-2015, 11:06 AM | #3 | |
Rep 91
Just wondering if anyone else has used the kit.... There are several parts that because it is BMW OEM the price is inflated, spark plugs come to mind here. Just wondering if this another case of that? Thanks! |
02-25-2015, 11:19 AM | #4 | |
Rep 5,508
Remember to add in shipping. That pushes the cost of the kit to $90.
Auto Detailing Enthusiast!
02-25-2015, 12:30 PM | #5 |
Rep 11,891
OEM fluid is p/n: 83-22-2-282-583 with the friction modifier
It comes in at around $42.31 (or even less) + ~ $12 of shipping for a 500ml bottle at various online dealership parts stores. So you're looking at $120 + shipping + cost of diff bolts if you elect to change the bolts as well. Yeah the Castrol non-friction modifier version is much much cheaper as it's 1/2 of the price. IMO, I would use OEM fluid, b/c that diff chatter drives me nuts.
22 Phytonic/Coffee X5 45e (CoVID-free)
08 Speed Yellow 911 GT3 Sharkwerks 12 AW/Cinnamon X5d Sports Pkg (retired) 14 AW/Beige M6GC ZCP, MPE, V2 steering wheel, vorsteiner (retired) 08 SSII/Black E90 M3 (retired) |
02-25-2015, 12:49 PM | #6 | |
Rep 5,508
The FM allows the diff discs to slip more so it works more like a open diff - not good for performance.
02-25-2015, 12:54 PM | #7 |
Rep 11,891
Hmm, I never thought of it that way.
02-25-2015, 12:58 PM | #8 |
BimmerPost Supporting Vendor
732
Rep 3,735
This fluid does not contain the "FM Booster" that these cars pretty much all need, or the diff will make noise at low speeds when turning. The FM Booster fluid is much more expensive than the non FM fluid.
BMW PERFORMANCE SPECIALISTS. Race Engines. Suspension. F/I. Brakes. Race Preparation. Factory Service. Alignments.
OFFICIAL PARTNERS: KW. MOTON. Brembo. AP Racing. BBS Motorsport. iND. HRE. Turner Motorsport. VAC. BMW Motorsport. Facebook | Instagram | Yelp! | Flikr Phone: 949-233-0448 | E-Mail: info@mrfengineering.com |
02-25-2015, 01:04 PM | #9 | |
Rep 91
I appreciate all the help and have convinced me to pony up the additional $ for the OEM fluid. For those that have changed their own fluid, is it worth or necessary to get new drain/fill plugs? The kit did come with those as well... Thanks! |
02-25-2015, 01:06 PM | #10 | |
Rep 11,891
02-25-2015, 01:07 PM | #11 |
Woof!
352
Rep 1,323
Drives: '11 M3 ZCP LeMans Blue
GKN Visco-lok compatible friction modifier is available as an additive in a low-cost 4 ounce bottle (Mopar 4318060AB). If your diff is noisy in tight turns (and you've already changed the fluid), you can add some or all of one of these small bottles and potentially fix the issue. As noted, friction modifiers alter the lock-up characteristics somewhat, and those stiction noises are not indicators of any trouble in most cases. For best on-track performance I'd leave the friction modifier out.
02-25-2015, 01:49 PM | #12 |
Rep 11,891
does anyone have the part numbers for the OEM fluid without the friction modifier?
02-25-2015, 09:50 PM | #13 |
Rep 468
After reading through this post (http://www.m3post.com/forums/showthread.php?t=714350 ) and others I decided to go with the Red Line fluid. I also ordered the spare plugs just in case something goes wrong...they are cheap insurance.
