03-05-2015, 11:40 PM | #1 |
Car Addict
Rep 54
Engine malfunction
Got an Engine Malfunction light tonight. Came on afte about a block driving out my house. Limited me to around 45 mph. Turned the car around and parked it. Started it up again a minute later, and it came on again.
What I did install was an IPE F1 exhaust. I did it on Sunday. Been driving the car everyday. Drove maybe almost 200 miles and got the light. Any ideas? Could the exhaust be it? I'll have to check in the morning underneath. Maybe an O2 sensor wire melted, O2 sensor undid itself? Not sure. Just throwing it out there.
2009 BMW M3 6MT | 1972 Datsun 510 SR20 |
03-06-2015, 12:07 AM | #2 |
Rep 315
IMO...really hard to say without hooking up to a tester and reading the error code. Recommend doing that first before speculating.
SOLD: 2015 F82 Yas Marina Blue / M Performance Exhaust / Black Kidney Grill
SOLD: 2011 E92 LeMans Blue / Volk RE-30 / CF: Spoiler, Splitters, Nostrils, Kidneys, Gills |
03-06-2015, 01:10 AM | #3 |
Car Addict
Rep 54
03-06-2015, 01:34 AM | #4 |
Rep 1,246
Drives: E92 M3
You don't have to turn the car on to pull the codes, they're stored.
03-06-2015, 02:19 AM | #5 |
Rep 315
Right on. Let us know what you find out.
03-06-2015, 10:45 AM | #6 |
Car Addict
Rep 54
Got the codes today:
P1209 - no dtc definition found - confirmed P2298 - pending: O2 sensor out of range during deceleration bank 2 sensor 1 - pending P1209 - no dtc definition found - pending |
03-06-2015, 11:23 PM | #8 |
Car Addict
Rep 54
Yes. When I installed, I had the two pipes (stock and IPE) laying side by side. On top of that, the connectors for post and pre cat have specific connectors, so it's next to impossible to install incorrectly.
But definitely something worth bringing up. Thanks. My game plan right now.... Car is still under warranty. I will bring it to the dealer to resolve the issue. Of course, remove the IPE exhaust first. I don't want them to turn me around due to catless system. Once we figure that out, I'll post my results here. But also, I will get a proper tune by Alex at Alpine in LA (Great guy to work with BTW). Thanks everyone.
03-06-2015, 11:32 PM | #9 |
Rep 6,733
2729 - P2298
Information saved in DME Fault code 2729 - P2298 Fault text Oxygen sensor, coast-mode diagnosis before cat., bank 2 Fault description O2 Sensor Out of Range During Deceleration (Bank 2 Sensor 1) Condition for fault identification Test condition: Oxygen sensor is available (via sensor temperature, no error code entries, etc.) but the AD value is less than 3398mV (K_LAVK_OBD_SA_SCHW) for a number of 2 (K_LAVK_OBD_SA_CNT) measurements . Terminal condition: Engine running - overrun condition . Voltage condition: none Condition for fault memory entry none Action in service 1. Check plug and wiring harness to pre-cat oxygen sensor LSVK B2 (focus on opens in wires for virtual ground and pumping current) . 2. Replace oxygen sensor Fault effect and breakdown warning MIL on after engine runs 2x Driver information Warning light: MIL Service instruction none |
03-06-2015, 11:33 PM | #10 |
Rep 6,733
27E4 - P1209
Information saved in DME Fault code 27E4 - P1209 Fault text Vacuum sensor, brake booster, plausibility Fault description Brake Booster Pump Shutoff Valve Plausibility Condition for fault identification Test condition: Constant violations of activation threshold or vacuum gradient is too low during activation . Terminal condition: TERM87 . Voltage condition: none Condition for fault memory entry 5000 ms Action in service 1. Check ELUP fuse, . 2. Check wires, . 3. Replace ELUP Fault effect and breakdown warning CC message . Engine speed limited . Reduced power . MIL after engine runs 2x Driver information Warning light: MIL, EML, CC message, backup program Service instruction None |
03-06-2015, 11:34 PM | #11 |
Rep 6,733
Giving credit to Regular Guy
http://www.m3post.com/forums/showthread.php?t=928325 |
03-07-2015, 04:12 AM | #12 | |
Car Addict
Rep 54
This one is very interesting because the IPE F1 exhaust relies on vacuum lines from the brake booster to operate the actuator on the exhaust. I'll check for leaks.
03-07-2015, 07:32 AM | #13 | |
Rep 1,470
Stoptech 380mm/355mm | PFC08 / Pagid RS-29 | Akrapovic EVO - CF tips | Benvo Tune | MS UDP | AA air filter | MCS 2-way with 700/1000lb springs | Solid bushings and adjustable links | RD front swaybar | Apex EC-7 18x10 square 275/35-18 NT01 | Turner Race Studs | GT4 Brake Cooling | GT4 Power Steering Cooling | Alekshop Oil Cooler | Performance Steering Wheel | | CF Spoiler | Varis System 1 Full CF Diffuser | Extended Paddle Shifters | Schroth Quick Fit Pro | Turner Steering Rack Stops | Vorshlag Camber Plates
03-07-2015, 11:48 AM | #14 | ||
Rep 6,733
03-09-2015, 10:39 AM | #15 |
Car Addict
Rep 54
Figured issue out.
Culprit was a vacuum line. The IPE exhaust system relies on vacuum pressure for the flap actuators to operate. The line had about a 1/4" inch cut which leaked. What prompted me to find this needle in the haystack problem was every time I shut down the car, I heard a hissing sound coming from the rear of the car. I cleared the codes, logged about 50 miles on the car and no reported check engine lights, reduced power (limp mode). All seems well for now. Thank you BzsBimmer for helping to diagnose!
03-09-2015, 01:15 PM | #17 |
Car Addict
Rep 54
Thanks to the forum! This proves that us collaborating together resolves issues we may have with our cars. This forum rocks!
03-09-2015, 02:14 PM | #18 |
PAZUZU
545
Rep 2,058
Drives: '15 M4
agree, glad you fixed your problem.
2009 M3 DCT ESS625+ SOLD 2015 M4 BSM/Silverstone F4LCON @texasMclub IG @jagemoets |
03-09-2015, 10:55 PM | #19 | |
Rep 1,947
03-19-2015, 12:12 PM | #21 |
BimmerPost Supporting Vendor
3391
Rep 7,543
Also fyi for anyone else experiencing the vacuum fault.. A lot of times this fault will throw cars into limp mode that recently had a brake fluid flush or change. The sensor is located directly under the brake fluid reservoir and if any fluid gets on it, the car will keep getting thrown in limp mode. Seen it happen a number of times. Hope this helps.
-----| Like us on Facebook | Instagram || Tuning Information | Remote Coding |----- ----Visit us at www.BPMSport.com - Emotion. Driven. | Toll Free: (888) 557-5133---- |
08-10-2015, 10:12 PM | #22 | |
Rep 173
2011 BMW M3
