03-06-2015, 04:55 PM | #1 |
Rep 2,975
Oil Consumption post oil change w/ Photos:
Hey guys,
Just recently had my oil changed at 20,000 mi. Post readings of oil level were right under MAX (perfect amount). Putting around 800mi on the car since then the oil level has dropped. Not significantly, or to "Add oil" warning, however that seems like an awfully short time to have already dropped? Or am I wrong. Oil readings right now are at the 2nd photo shown. In your experience, is it safe to add 1/4 quart to get back up to where it was right after change? What is the "ideal" spot for our oil to be at all times. Thanks! (Right after oil change) (Now - post 800 mi) |
03-06-2015, 07:22 PM | #2 |
Rep 275
My experience is that it takes a while for the car to accurately reflect the oil level after an oil change. I just changed my oil as well and started out adding 8 liters with the car showing 1/4 liter low after. After gradually adding and checking 1/4 liter at a time (with no change to the indicated oil level) it suddenly showed an overfill after 9 liters. After driving about 100 miles, it settled out to right at max. I would also take your past oil consumption into account. If consumption wasn't high before the oil change then I doubt it actually went through 1/4 liter in only 800 miles.
As long as your above the min you should be OK. If you want to add oil, I would do so 1/4 liter at a time and drive it around for a while before checking again. |
03-07-2015, 05:15 PM | #4 |
Rep 595
The perfect amount is between min and max. If there was a perfect amount the oil reading wouldn't have a range, it'd either be good or bad.
2022 Nissan Armada (big couch)
2017 Camaro SS 1LE - Gone 2008 SSII E90 6MT - Gone 2009 SG E92 DCT - Gone |
03-08-2015, 11:56 AM | #5 |
Rep 2,975
03-11-2015, 10:16 PM | #6 |
Rep 1,017
Drives: 2010 E92 M3 6MT
Usually when you are low enouf to have it fuss at you about adding oil you only need 1/2 qt to top it back off.
Since you got 9qts in there your more than safe.
4.4L LC stroker/ESS VT2-625/Volk te37 sl's/AA exhaust/DSS Carbon Fiber driveshaft/ARH Headers.. etc |
