03-25-2015, 02:40 PM | #1 |
Rep 66
aFe Cold Air Intake 32hp gain??
03-25-2015, 04:27 PM | #2 | |
Rep 592
03-25-2015, 05:48 PM | #3 |
Rep 764
I don't buy it. You're not going to pick up that kind of gain on a turbocharged engine just by reducing intake restriction.
The turbos are reaching peak pressure with the stock intake based on waste gate control. Reducing intake restriction may allow the turbos to spool a little quicker perhaps reducing lag and adding a little low end torque (you will reach peak boost sooner). But max boost remains the same. You are not going to gain 32HP without increasing boost. Last edited by Bönz; 03-26-2015 at 06:19 AM.. |
03-26-2015, 01:13 AM | #4 |
Rep 18,794
I don't buy that number.
Air intakes on turbocharged car won't affect much by itself. But it does help if you have other mods. Think of it as the nose strip that athlete uses. It just help them to have better air flow by lifting your nose skin up. Unless you care about the finish look, I would just get the BMS Air Intake. Much2 cheaper and work the same way.
Email:sales@rgsport.com | IG:RGSport_USA | Web:RGSportShop.com Memorial Day SALE!! 05/24 - 06/03 • Coupon Code: "MEMORIAL" MSS • iSweep • RaceChip • Sterckenn • AutoTecknic • Akrapovic • Vossen Wheels • Eventuri Active Autowerke • KW • H&R • Ohlins • Remus • and more... |
03-26-2015, 06:19 PM | #6 |
Rep 592
