04-05-2015, 05:36 PM | #1 |
Rep 268
Z4M VF570 install help needed
Hi guys,
Reaching out here to see if any of you with VF570 experience can help me out? I'm really stuck on hooking up all of the vacuum/boost lines. I will reach out to VF of course, but it's the weekend I am installing the VF570 with a Tial 50mm BOV, See attached photo. 1. This normally ties into the stock VF BPV. With the Tial I see no application for it. Cap it off? 2. Do I run a line from this down to the engine to drain any fluid, or something else? 3. This used to plug into the stock air box, I see no application for it now? 4. I am hooking up a boost gauge in the cabin, I believe I can get a boost reading off of this T? 5. Does this connect to the nipple on the bottom of the Tial (#7), or somewhere else? 6. Not sure what this elbowed nipple is for. 7. I installed the nipple that came with the Tial BOV I ordered from VF. Not does this connect to #5? 8. This is a larger nipple, about double the size of #6. Not sure what application there is for this. Thanks to all who can help provide insight. |
04-05-2015, 06:11 PM | #2 | |
Rep 1,130
