04-14-2015, 11:53 PM | #1 |
Rep 252
ebay oil catch can
Saw a bunch of oil catch cans on ebay that looks just like the bms can. Anyone try it yet? Just the can alone is under 80bux. Its a lot cheaper then bms
http://www.ebay.com/itm/231530732389?redirect=mobile |
04-15-2015, 03:43 PM | #2 |
Rep 1,051
If I didn't already have a BMS can and I was in the market I'd probably give it a go.
Take one for the team?
2009 BMW 135i 6MT Sport, AFE intake, Cobb AP, Apex 18x8.5+9.5, 255/275 PSS
04-16-2015, 02:14 PM | #3 |
Rep 3,323
Don't take one. Don't take any. Did much research on this site and the OCC does very little or nothing to improve your vehicle. I'm not saying it's smoke and mirrors but not enough proof for me to install one. JMHO....
Sparkling Graphite Metallic / 6MT / Terracotta Boston Leather / Sport Package / Comfort Access system / Gray Poplar wood trim / Heated front seats / iPod and USB adapter / HD radio / Premium hi-fi system / OE Tuning / VRSF Intercooler & charge pipe / BMW Performance short shift kit / BMW M Performance Handbrake Handle / BMW Stainless steel pedals / V1 hardwired / rear sun shades Pennsylvania 20 electoral votes
04-16-2015, 02:45 PM | #4 |
The Crowing
111
Rep 2,005
i would look into getting one, specially if your tuned. when i removed my intercooler and charge pipe they were coated in oil after 50K miles. you could see the oil drip if i held it up long enough. i think it all depends on your car. seems that each car is different. from what i've been hearing most N55's dont really need it much, but i'd spend $200 or less if its used, just to not have to clean my valves again. I have a DIY on valve cleaning and you can see how they looked. you can also read some other peoples takes on the subject here, http://www.1addicts.com/forums/showt...an+worth+it%3F and here http://www.1addicts.com/forums/showthread.php?t=969175. This is my valve cleaning thread, http://www.1addicts.com/forums/showt...valve+cleaning as you can see my valves are pretty dirty. car was tuned around 30K miles and that was at 55K. if a $200 part, or cheaper if you go that ebay route, will make me not have to do this again then totally worth it. i got a used BMS occ for cheap this past winter so i have to install that. curious what i'll catch in it this summer.
2009 135i : BMS JB4 G5 ISO,CXRacing FMIC Kit,Injen Cold Air Intake,Evolution Raceworks Charge Pipe,Walboro Inline Fuel Pump, E85 BMS Backend Flash w/ 60% E85,BMS Meth injection (trunkmount),BMS dual meth nozzles,Spec stage 2+ clutch w/ steel SWFW,BMS Catless Downpipes,Berk Tech Race Axleback |
04-16-2015, 03:16 PM | #5 |
Rep 31
I bought this one because it included the hoses. I made an offer on it which knocked it down a couple bucks too.
http://www.ebay.com/itm/BMW-135-1m-3...18376b&vxp=mtr Fit and finish is great. Only issue I had was that the mounting strap is not correct for our brace... I messaged them and they said it was tested on an e90. They offered to take it back or give me a credit (~$20). I took the credit and made a strap from some metal strapping and heat shrink. Here are the pictures I sent to them explaining the issue. |
04-16-2015, 03:21 PM | #6 |
Rep 3,323
I don't know ..the thing could catch a little oil over a 12 month period and how would you know if carbon is building up or not? You would have to pull the manifold in order to check that. Not worth it for me. I'm getting my second blast next month. I'll have around 92K then. For $500 once and done clean intake. I have spent enough money on this car to spring for another $200 - 300 on a product that "might" work. I need more Proof!
04-16-2015, 03:57 PM | #7 | |
The Crowing
111
Rep 2,005
04-16-2015, 06:04 PM | #8 | |
Rep 2,233
04-16-2015, 06:54 PM | #9 |
Rep 3,323
I don't agree with that statement.
50K is 4 1/2 years for me. 5 or 6 if I get a winter beater, which I plan on doing soon. I don't think I'll be keeping the car forever. I'll ask my indy shop what they think, They seem to be very knowlegable about these cars. I'll let you know. I drop the car off with them May 4 for the blast and shocks.
04-16-2015, 07:02 PM | #10 | |
The Crowing
111
Rep 2,005
04-16-2015, 11:19 PM | #11 | |
Rep 252
We get pretty cold winter here. A catch can should also help with catching condensation in crankcase also and not just oil in summer. For the price of this ebay catch can, it would be cheap insurance. That's what I think. |
04-16-2015, 11:37 PM | #12 |
Rep 917
Please don't buy this. This part was developed and tested by BMS so it should be purchased from them. They deserve the credit for this. It's not a lot of money to just buy it from the guys that designed the thing. You'll get it in 2 days and you'll know you can call on BMS with any problems, install questions, etc. Don't be cheap asses.
2011 135i M Sport 6MT LeMans Blue | Active Autowerke Gen II axle back | Berk d******* | N54 gutted mids | FuelIt Walbro 450 fuel pump | Pure Turbos Stage 2 | 3.5bar TMAP | Pure Turbos inlet pipe | BMS intake | BMS oil catch can | ETS intercooler | ETS charge pipe | BMS JB4 w/ ISO firmware | BMS backend flash stacked on PPK | Eibach springs | Whiteline rear subframe bushing inserts | cosmetic tidbits
04-17-2015, 07:16 AM | #13 |
Rep 3,323
What are we looking at?
04-17-2015, 08:32 AM | #14 |
Chief Warrant Officer
1025
Rep 1,638
I have the BMS OCC but I haven't installed it yet, partially because I am not yet sure my car needs it (I'm an N55, so I just need to check for residue when I get a chance).
I will say, however, that the build quality on it is absolutely top-notch. It's actually a beautiful hunk of metal with amazing fit and finish. I don't know if the same can be said for a knockoff. So, if you are going to get an OCC, I would suggest springing for the BMS one. Look around at some of the other vendors like x-ph and such, you may be able to get a slight price break on the BMS can, but that is the one to get.
"Prius" is Latin for Eunuch.
"Hrothgar": 2012 135i: 6MT M-Sport, BSM/Blk; Nav, Premium, Convenience, HK Dinan Stage 2 +PPK /// BMW PE /// VRSF CP /// K&N /// Koni Sports /// RSFB Inserts /// MPS4S 225/255 /// Other Stuff |
04-17-2015, 09:16 AM | #15 |
Rep 952
From what I've seen with OCC on an N55, it just collects watery rusty looking stuff, not really oil. I had my manifold off around 65k to do my oil filter housing gaskets and there was zero buildup on the valves. The ports were black, but none of the crusty buildup like you see on N54s.. That's why I didn't spend $$ on an OCC. My .02
13 X1 35iX, 98 Z3 2.8, 01 M Coupe, 96 Z3 1.9 DASC, 95 318ti, 13 smart fortwo
04-17-2015, 09:31 AM | #16 |
1025
Rep 1,638
A question on OCCs in general:
Most of us (at least the one who mod) are obsessive about reducing restrictions to the car's breathing system. We add intakes, better charge pipes, DPs, etc. it seems to me that an OCC is adding an additional restrictive element in the airflow system, and given the design (lots of small holes in a plate) it seems like it would create turbulent airflow in addition to a physical obstruction. Thoughts?
04-17-2015, 09:42 AM | #17 |
Rep 917
That's the crud collected from a BMS N55 catch can.
11-23-2020, 03:45 PM | #18 | |
Rep 277
So it's basically wasted gasses and oil/gas residue, it's not robbing the intake or creating a bottle neck in the intake or exhaust side per se. it's a completely separate system if you want to call it that. |
11-30-2020, 06:35 PM | #19 |
Rep 2,084
The BMS catch can is only in use when the car is "in boost", or in other words when there is positive pressure inside the intake manifold. This only occurs during medium-heavy acceleration or powering up hills, which, depending on your driving habits, is likely no more than 10% of the time the engine is running.
The real benefit is to run the vacuum side through a catch can which will be in use the other 90% of the time and will catch a hell of a lot more. On my N54 it was easy enough to "externalize" the vacuum side PCV system out of the valve cover and route it through a catch can and back into the intake manifold. Not sure about the N55 though. I bet it can be done if it hasn't already.
2013 135is DCT Carbon Black Metallic |
