04-15-2015, 11:37 AM | #2 |
Rep 128
M3Aviator, The install involves lowering the subframe. Engine is supported from the top. There is absolutely no need to remove the engine. You don't have to remove the subframe altogether either. It needs to be lowered just enough to remove the stock manifolds. The heat shields are the only thing we recommend deleting. They are no longer needed and having them out of the way makes bolt access far easier. The stock studs and nuts can also be reused. Please feel free to PM me a contact number and I'll call you with all the details. If it's easier you can reach me at 631-608-1986. Thank you.
Nick |
04-15-2015, 11:39 AM | #3 | |
Rep 3,633
Why are you so quick to say the heat shields can be deleted? Although I really don't see an issue with it, many SC run the filter right over the DS side header and this will create a ton of heatsoak. |
04-15-2015, 12:02 PM | #5 | |
Rep 128
Nick |
