04-29-2015, 09:16 AM | #1 |
Rep 15
4 problems
Hi Overthere,
I hope some of you have had the same problem and knows the solution. The car has only driven 51.000 km. Here goes the list: 1. Unlock the passenger door does not happen before you pull the lever inside. I suspect GM5 module. Other suggestions? The car is LHD. 2. When I turn on Climate pump / air conditioner it sounds like a helicopter flaps around just above my head. Not loud, but enough to annoy. Missing fluid in the system? 3. When starting the car when it is COMPLETELY cold, it may give a squeal, just when the engine jumps started. Otherwise nothing. Worn belt or bearing? 4. When I keep the car in the coupling point (just where it engages slightly), it "rattles" a bit. Clutch release bearing worn (do not know if it's called that in English?) or? |
04-29-2015, 09:36 AM | #2 |
Rep 11,669
1. I recall discussion on this but don't recall the solution; others will comment im sure
2. not sure about this from your description of the sound. 3. how old is the car? regardless of low kms it could be the belt needs replacing. also do the tensioner at the same time. 4. This 'rattle' at the engagement point is normal on dual mass flywheels. it makes a great difference on how you engage clutch & throttle (timing of the pedals)
'21 M2C Hockenheim Silver
'18 718 Cayman S Lava Orange (sold) '13 E92 M3 Santorini Blue (sold) '07 Z4 M Coupe Alpine White (sold) |
