04-29-2015, 11:23 AM | #1 |
Rep 8
X5 M50d full brake set
Hi Everyone,
Finally I received my new M50d a couple of weeks ago (was sort of long long wait, nearly 6 months). Before delivery I decided to have the M Performance brakes installed thus I have a set of brakes unused sitting at the dealer's service centre. This may not be the best to post for a sale, but if anyone interested in getting it, I'd be more than happy to sell mine. Apart from the brake, can anyone answer if the additional Dynamic Adaptive suspension (2VP) is coming with a lot higher drive position? I feel the car is a lot lot higher than other F15 without this option. |
04-29-2015, 03:33 PM | #2 |
Rep 193
I do not know which models will fit your set....30 or 40d....
Not a lot of people want to change it as car is still under warranty and majority of people have service included(including brakes replacement). But still think that best option is that you will post it on ebay P.S. Where are pictures of the car ? |
04-29-2015, 04:16 PM | #3 |
Rep 198
Hi,
What exactly are the M performance breaks? I am pretty sure that the M50d comes standard with some sort of modified m brakes: twin-piston floating-caliper 385 x 36 front and single-piston floating-caliper 345 x 24 at the back. what are the specs of the once you got and how much did they cost you? Thanks P.S. I am pretty sure that the standard M50D brakes can fit only on wheels 19" +, guess it might be good info for the potential buyer |
04-30-2015, 02:34 AM | #4 |
Rep 346
04-30-2015, 12:58 PM | #6 | |
Rep 10,185
X5M gets floating discs (also known as compound discs), M Sport are standard type discs but the same size
BMW if you are reading, I need a job, Please. |
04-30-2015, 01:06 PM | #7 |
Rep 10,185
M50d brakes
Front 385x36 Standard discs,Floating single piston calipers Rear 345x24 Standard discs, Floating single piston caliper X5 MSport brakes Front 395x36 Standard discs, fixed 4 piston caliper Rear 385x24 Standard discs, floating single piston caliper X5M Front 395x36 floating discs with fixed 6 piston calipers Rear 385x24 Floating discs with single piston floating calipers
05-04-2015, 05:21 AM | #8 |
Rep 1,597
Drives: MY2022 X5 M-Sport 45e White
You would have been better off painting the M50d calipers and placing ceramic pads into the calipers. The M50d brakes work well and with the proper ceramic pad material (not EBC) you get no brake dust.
MY22 X5 M-Sport 45e White, 22"rims, Red Calipers, Ceramic Pads. Better off saying what it does not have and that's a B&O Audio System, otherwise all option boxes are ticked. |
05-04-2015, 09:04 AM | #9 |
Rep 346
05-05-2015, 03:22 AM | #11 |
Rep 1,597
Don't think so, there is no gap between caliper & rim with 20's?
05-07-2015, 07:44 AM | #12 |
Rep 360
Drives: 1M; E90 M3 ZCP; M4 GTS
100% the same brakes as the E70 X5M. I had a 2013 X5M before the 2015 X5 50i with M Performance Brakes, it's almost like I just moved them over. Upon installation on the F15, the difference from the stock setup wasn't as immediate as I thought it would be. After bedding and break-in though, it is notably better...I'm very pleased with the upgrade.
Check with your BMW Center, I believe 19" will clear and are the minimum required diameter. I too am trying to sell my OEM setup for not much money at all on Craigslist...heck of a deal for rotors, calipers, pads, sensors, shields and hardware. Was hoping someone with an E70 would jump on them. No takers unfortunately.
-kskpsu
05-07-2015, 07:55 AM | #13 |
Rep 360
Here they are with my winters on the 20" 469M and my summers on 21" Forgestar CF10s. Looks like 19" should be OK.
-kskpsu
05-11-2015, 06:34 PM | #15 | |
Rep 1,597
How much do you want for the front & rear calipers?
01-27-2018, 06:33 AM | #18 | |
Rep 525
on the right 2vp package . |
01-27-2018, 04:25 PM | #19 | ||
Rep 7,165
Drives: F90 M5 / F15 50i
'07 Yamaha R1 (sold)
'06 C55 AMG (sold) ‘?20 M5, MP Carbon Pro Spoiler, MP Carbon Diffuser, MP Black grille and gills, MP Carbon Mirrors, CF side sills, 789M w/ Ti studs, eventuri, Dinan X pipe '14 X5 50i (wife’s now) |
