BIMMERPOST Universal Forums Off-Topic Discussions Board Put the wrong gas in my mower, am I fucked?
      05-07-2015, 10:59 AM   #1
chris82
chris82's Avatar
Drives: 128i
2009 BMW 128i  [9.80]
Yea, that happened. Instead of the 93 I put in it, I put in a mixture of oil + 93 that was for my 2 stroke bushwacker lol. It took at least 3/4 a tank of this bad gas. I forgot they were mixed. So I mow half the lawn, and it finally dies, and I can't start it up. Once I figure out that I put the wrong gas in, I dump all that gas out and unhook the fuel line that goes to the carb to drain it completely. Then I fill with premium 93. Now I can't start the mower, so I take off the air filter and start gently putting very small amounts of gas (like a few drops) directly into the carb, and that continues for 10-20 minutes. It's still sputtering, but I can keep it running as long as I'm doing this. After about 10 minutes of this, the mower starts running like new. It's not sputtering, and runs fine for 8-10 minutes at the normal RPM. I was able to cut some of the lawn and no problem. Then all of a sudden it starts sputtering again and eventually dies. I can start it up, but it dies again in 10 seconds or so. My next step is to clean the carb, anything else that needs to be done? Am I fucked here? I mean, I have a full tank of fresh 93, I emptied the fuel line, and got it running for 10 minutes and cut some of my lawn with it, what could possibly cause it to cut out after that!?
      05-07-2015, 11:04 AM   #2
upstatedoc
I'll get back to you
upstatedoc's Avatar
7546
Drives: blue streak
You put 93 in your lawnmower?
Me too.
Check the spark plug
2018 Stinger GT
2009 E90 N51 /Active Autowerke Stage 2 tune/BMW Performance Exhaust/
Countermeasure enthusiast.
      05-07-2015, 11:12 AM   #3
Templar
Templar's Avatar
Drives: 2011 E92 M3
2011 BMW M3  [10.00]
Should be fine, as mentioned above check the spark plug. Oil/gas mix for a 2 stroke engine won't really mess with the 4 stroke mower engine all that much except some people say it might cause some smoke. Not a big deal though.
'11 BMW E92 ///M3 - ZCP and DCT
'15 Ford F-250 - Lariat, 6.7 Powerstroke Turbo-diesel
      05-07-2015, 11:14 AM   #4
Taskmaster
Japan
2482
Drives: M235i 6MT / E92 328 Msport 6MT
It's screwed, you're screwed, abandon ship and don't look back!
      05-07-2015, 11:22 AM   #5
P1
P1's Avatar
11736
Drives: 2004 3/4 ton Duramax
I run 93 in my mower also! I keep the fuel for my Honda mower and my Echo completely separate.
      05-07-2015, 11:30 AM   #6
fcman
Drives: 2023 G87
Did you mistake your lawnmower for an RX7?
      05-07-2015, 11:38 AM   #7
upstatedoc
upstatedoc's Avatar
7546
Drives: blue streak
My bushwacker and blower are electric (Li+) so no worries for me.
2018 Stinger GT
      05-07-2015, 11:49 AM   #8
chris82
chris82's Avatar
Drives: 128i
Me too.
hell yea, gotta get that extra hp!
      05-07-2015, 11:51 AM   #9
Whostheboss
Whostheboss's Avatar
424
Drives: a 9incher
93 on lawnmower? baller. I'll put 85 if can, shit ill put kerosene if i can. LOL
WHO'S THE BOSS
      05-07-2015, 12:04 PM   #10
Super + stabilizer goes in every gallon I get for the mower.
I once had access to an oil that worked for 4 stroke but was also compatible with 2 stroke, so you could just mix and not have to worry about your oh-so-attentive sons putting the wrong fuel into a machine and burning it up. Can't find that product any longer, the shop where I bought it went out of business.
      05-07-2015, 12:36 PM   #11
Taskmaster
Japan
2482
I don't think you should run higher octane in them, I'm sure it's probably like a car where the combustion cycle in a car, where if it isn't tuned to run on 93 - you'll not have a complete combustion and actually lose power and mileage.
      05-07-2015, 01:00 PM   #12
Mr Tonka
is probably out riding.
Mr Tonka's Avatar
Drives: Something Italian
Fill tank with straight octane booster. Mow lawn in half the time.
"There is no greater tyranny than that which is perpetrated under the shield of the law and in the name of justice. -Charles de Secondat"
http://www.m3post.com/forums/signaturepics/sigpic59612_1.gif
      05-07-2015, 01:08 PM   #13
chris82
chris82's Avatar
Drives: 128i
Not a bad idea to get this thing running smooth again.
      05-07-2015, 01:38 PM   #14
Mr Tonka
Mr Tonka's Avatar
Seriously though, best case you fouled the plug, which is no big deal. Worst case you clogged a fuel filter, (if there is one) which is also no big deal.
Pull the plug and soak the tip, without bending it, in gasoline to get all the oil off, let it dry, reinstall. Or just get a new plug. Once you get it sparking again, it'll likely smoke until it burns off all the oil in the combustion chamber.
      05-07-2015, 01:40 PM   #15
chris82
chris82's Avatar
Drives: 128i
Spark plug sounds likely . . . dammit this is a PITA
      05-07-2015, 01:41 PM   #16
954Stealth
954Stealth's Avatar
Drives: A Car
Originally Posted by Billup View Post
You know you're getting bacon, when you're cooking bacon.
      05-07-2015, 03:09 PM   #17
Yeah, if you have to pull the plug, might as well go for an upgrade
      05-07-2015, 06:03 PM   #18
MrPrena
MrPrena's Avatar
Drives: BMW Hyundai Nissan
me2. no high compression engine, lower octane rating will do.
85 on my lawn engines. I do oil change and tuneups every year or more.
Tired of buying new mowers.
Beware of Jeff Oliver the fraud at Highland Expedition Outfitters (aka HEO or HEOutfitters) located in Cosby TN.
      05-07-2015, 07:05 PM   #19
kevinbahnz
kevinbahnz's Avatar
159
Drives: 2008 335xi sedan
sometimes i use non ethanol gas in mine
<img src=http://i189.photobucket.com/albums/z164/kevinbahnz/08-23-2008030.jpg border=0 alt= />
      05-07-2015, 08:13 PM   #20
jaco
Drives: 2011 E90 M3 SSII
Damn 93 Octane. My Honda mower only gets the finest 87 octane.
Jacob
2015 Chevy SS In
2011 E90 M3 DCT SSII Out
      05-07-2015, 08:26 PM   #21
chris82
chris82's Avatar
Drives: 128i
Haha 93 for me. Anyways, problem fixed. Took the carb off and emptied all the gas I could out of the metal bowl at the bottom of it. Managed to put it back together (that's the amazing part), started up on the first pull and back to normal.
      05-07-2015, 08:32 PM   #22
Douche
Drives: Car
FWP
