05-20-2015, 09:43 AM | #1 |
Rep 73
wheels spacers good for performance?
I'm looking for advice regarding wheel spacers. I plan to track my M3 and love the look of the 15 mm Macht Schnell's. Of course they tout the wider stance they give your car as a handling aid, but I am wondering about the cornering stress on the longer lugs, any additional play they may introduce, and added rotational mass from the spacers themselves. Am I worried about nothing, or are these legitimate concerns and I should avoid spacers?
05-20-2015, 02:42 PM | #2 |
Rep 3,834
You'll be fine. Although 15mmx2 width isn't going to increase performance. Get MS stud conversion while you're at it. It's much easier to swap out wheels with spacers.
Daily: G12 750 MSPORT Weekend Car: E90 M3
05-20-2015, 06:33 PM | #3 |
Rep 20,742
Drives: 2021 911 turbo
For optimal handling performance, stick with the OEM offset (i.e. No spacers for stock wheels).
Spacers should only be used to bring back a wheel that does not have the correct OEM offset to start with. Changing the offset alters the spring and damper ratio relative to wheel travel. Further, on the front axle, spacers also alter the scrub radius and the required ackerman angle as the wheels are steered.
Porsche 911 turbo 2021 992 GT Silver
Previous cars: M4cs 2019 F82 Limerock Grey / M4 2015 F82 Silverstone / M3 2008 E92 Silverstone / M3 2002 E46 Carbon Black |
05-22-2015, 01:12 AM | #4 |
Rep 73
good to know! thank you.
