05-24-2015, 12:37 PM | #1 |
Rep 232
Aftermarket chargepipe question
I had a question about the chargepipe. The claims that it holds boost better and increases response are they true? At one end the tubing coming from the IC is plastic so of course that plastic is going to give and the aluminum CP is not going to work correct?
Are people just upgrading it for bling/noise or is it for reliability? With the aluminum CP the next weak link would be the plastic tubing from Intercooler to CP correct? |
05-24-2015, 12:48 PM | #2 |
1Addict
3242
Rep 7,910
The stock CPs like to pop off under boost. Even stock levels of boost can do it.
Most aftermarket charge pipes are 3", this is due to the bend right before the throttle body. Upping the diameter helps reduce resistance and turbulence due to the bend. Otherwise, it's best to keep all hot side piping as small as possible without introducing turbulence.
05-24-2015, 02:15 PM | #3 | |
Civil Rights Activist
115
Rep 949
The part that commonly fails is the part nearer to the throttle body, near the C-Clip, where the most resistance occurs. I upgraded mine just because of the bling. I got a chrome CAI and a cusco strut tower bar with yellow plug wires, too. I know it's a coil pack ignition, but I like the way plug wires look.
E88 Crimson Red Vert MSport 6MT - Listing your mods in your signature is lame. BMS DCI/MHD E30 Flash!!/AA Sport FMIC/VRSF CP w Tial BOV/VRSF 3" DPs/550i clutch w SPEC SMFW/Apex EC-7s/Whiteline RSFB/E92 M3 FCAs/Bilstein B12 Pro Kit/VRSF inlets |
05-25-2015, 11:11 AM | #4 |
Rep 71
Trust me - when they fail- they explode off the throttle body and your lucky if you can find the C-Clip. Its better to replace them before they get that way. I was running a Stage 1 aggressive Cobb OTS tune when it failed at 54K
05-28-2015, 02:41 PM | #5 | |
Joint Chiefs of Staff
24477
Rep 191,450
Upgrading the charge pipe to a good aftermarket option will prevent that from happening. If you are looking for a better sound, get a BOV. If you are only looking for reliability get charge pipe with OE DV
