06-10-2015, 10:07 AM | #1 |
Honey Badger
25
Rep 321
My oil level is at the bottom tic for loyal and I went to the local BMW dealership and they recommended I add two quarts.
I added the oil and now the max level is at the bottom tick is this an overfill? nothing is leaking out of the oil cap so is it harmful? |
06-10-2015, 10:11 AM | #2 |
Rep 1,320
Stop driving....yeah never add 2 quarts all at once! I know somebody is going to chime in here and scold you, but for future reference only add in 1/2 quart and drive for a bit and let the sensor re-calibrate, then add another 1/2 if low.
06-10-2015, 11:32 AM | #4 |
Rep 734
Either drain the front as leonardo suggested, or you can turkey baster some out of the oil filter housing a couple of times and see if that helps.
94' NSX - Garage Queen
97' Integra Type R - Track Warrior (Sold) 01' BMW E39 M5 (Sold), 2x 02' BMW E39 M5 (Sold & sold) 08' E90 M3 6MT - DD 13' W212 E63 AMG Wagon |
06-10-2015, 11:39 AM | #5 |
Rep 650
From everything I've read, you should only add oil when the car says so... And it should say so at the bottom tick.
And from what I've seen, the difference between the top tick and the bottom tick on the oil level in the dash is one litre. So adding 2 quarts when the oil is at the bottom tick would be too much... You will get oil frothing in the pan which may cause oil starvation in the engine and that would be bad...
Today's gains far outweigh tomorrow's losses.
06-10-2015, 11:53 AM | #6 | |
Honey Badger
25
Rep 321
06-10-2015, 06:43 PM | #8 | |
Honey Badger
25
Rep 321
06-10-2015, 07:16 PM | #10 |
Woof!
352
Rep 1,323
Drives: '11 M3 ZCP LeMans Blue
Close, the min-to-max scale is a one liter difference (1.06 quarts). Since the e-meter can only show one-quarter liter increments, there will be some rounding errors to the nearest quarter-liter, and other factors (like how close to level the car is) that affect accuracy on this thing. See other threads on this...
06-10-2015, 09:30 PM | #11 |
Rep 170
06-11-2015, 10:10 AM | #12 |
Rep 2
This is exactly what we do in the shop just make sure you start and run it for a couple seconds in between and don't split the seal. also the faster you can get to the housing the more you can get out each clip.
06-12-2015, 10:00 AM | #13 |
Honey Badger
25
Rep 321
My local shop in Poway just put it up on a lift and drained 2 quarts out of the plug. Now the lvl sits right between ok and max.
