06-26-2015, 04:32 PM | #1 |
Rep 152
77k miles, what maintence to do to keep it forever
hey all
So as the title suggests, I have an 08 with 124k Km's (about 77k miles) on it. I won't be letting go of it any time soon, with plans to eventually add suspension, engine, and tire upgrades. I also plan to fix the exterior of all the chips paint defects she's received over the years. A bit of background: I bought this car with pretty much my life savings. It was on the cheaper side for an m3, with various paint chips/ scuffs/ seat wear etc, but I needed an e92 and I haven't regretted my decision yet. That being said, I have no clue what the previous owner had done as far as preventative maintence, and BMW dosent have much info for me either. So, we get to the question. What do I do now, and going forward, to be positive I will get years and years of enjoyment out of this thing? Possible issues I've noticed recently - a bit longer cranking on cold start - second gear syncros are weak ( I think whoever owned this before me was a bit rough on the trans) Use: I commute in it every day, autocross as many weekends a year I can, and if I can afford it a track day now and again. I would say it only works hard on weekends. I have been going through the whole site, from bearings to plugs to everything, and I can't really figure out what are 'must do' items and what are 'maybe do if you have the cash' items. Thanks all! K |
06-26-2015, 04:51 PM | #2 | |
Rep 955
since you said you read lots of stuff on here, i wont mention all the usual suspects... but, in my case, when i bought my used e92 m3 with 65k KM on it, the 2 maintenance items (aside from the usual stuff) that was well worth doing was:
a) my break fluid was toast. all the hydraulics worked good and all, but the mechanics said it was past due to have it changed. b) i'm 6mt as well, and bmw states that the tranny fluid on these cars (dct and 6mt) is life time. its not. i had them replace it, and noticed a significant improvement in how the transmission felt. unless you do it at a dealer ship OR have access to BMW software.... you can't change "all" of the fluid as quite a bit stays behind the transmission fluid pump. i had them do it twice, with a quick drive between so that in essence we changed 75% of it. i now have access to the BMW software, so next time i can force the pump to turn on with the vehicle off. oh and last but not least, if it already hasn't been done... see if you can get the DME (main computer that controls the motor) software upgraded to the latest 240E (err... 241E now i guess). theres quite a difference between one of the versions. people have reported improvements in how the vehicle starts with the newer revisions. 2008 canadian, so unless the previous owner(s) had it done, your possibly running one of the first versions of the software. enjoy! Quote:
06-26-2015, 06:30 PM | #4 | |
Rep 152
Thanks again! |
06-26-2015, 06:32 PM | #5 |
Rep 152
06-26-2015, 06:41 PM | #6 |
Rep 363
According to Malek@MRF none for the diff. The diff bolt has been known to shear (which can potentially ruin the differential $$$) but the solid bushings will prevent that from happening
06-26-2015, 10:37 PM | #8 |
Rep 10,684
Brake fluid
Trans fluid Power steering fluid Diff fluid Coolant Spark plugs Motor mounts Software update Diff mounts (but if you have a quiet exhaust don't believe anyone who tells you solid or delrin or hard poly won't be whiney) Consider rod bearings Air filter Cabin filter |
06-27-2015, 02:50 AM | #9 | |
Rep 7,140
A BMW dealer can check the software status in 5 seconds putting your key in their reader. They usually have this by the desk so a blink job during initial chat. That read gives a sw revision number, easy enough they can then print the content including all various sw modules such as engine/DME etc. Don't take BMW dealers no for an answer... Last edited by Helmsman; 06-27-2015 at 03:44 PM.. |
06-27-2015, 10:38 PM | #10 |
Rep 152
06-27-2015, 10:39 PM | #11 | |
Rep 152
06-27-2015, 10:40 PM | #12 | |
Rep 152
Thanks a bunch, didn't realize it was this easy. I'll be taking it in asap to see what I'm running. To confirm, the newest is 241E? Thanks! |
06-28-2015, 09:06 AM | #13 | |
Rep 112
This is a great list. Things I would add as you approach 100k miles.
Pre cat O2 sensors Keep your eye on your guibo/flex disk Oil level sensor- mine seemed to be off enough that I changed mine. Fuel pressure sensor - easy DIY. Sits behind the intake box. And since you have an 08 with the leaded bearings I would do frequent oil changes (5k to 7k miles) and get a black stone oil report. Condition your leather Quote:
06-28-2015, 10:13 AM | #14 | |
Rep 7,140
depending on the dealer they might not even know. If you get the "ISTA" revision (the way I remember it; E89-15-5xx, where 15 stands for year), you will be able to cross check with for instance Mike Benvo's list. Don't have it avail on my phone. Alternatively the dealer give you a print out with a series of numbers per module which you again could get help on this board to check. I like the above suggestion btw: condition the leather. The novillo is great but quite fragile, however rewarding to look after! Cheers |
06-28-2015, 03:31 PM | #15 | |
Rep 152
Adding to the list, thanks! |
06-28-2015, 03:32 PM | #16 | |
Rep 152
06-28-2015, 03:34 PM | #17 | |
Rep 112
http://www.realoem.com/bmw/enUS/show...diagId=26_0202
06-28-2015, 07:56 PM | #18 |
Rep 9,034
No one's going to recommend a Blackstone report?
And if you're going to do engine mounts, you might as well do the bearings when the new bearings are released, hopefully in Sept. .
Let me get this straight... You are swapping out parts designed by some of the top engineers in the world because some guys sponsored by a company told you it's "better??" But when you ask the same guy about tracking, "oh no, I have a kid now" or "I just detailed my car." or "i just got new tires."
06-28-2015, 08:08 PM | #19 | ||
Rep 623
Front lower control arms tie rod ends check rear trailing arms since they can bend easily |
06-28-2015, 10:19 PM | #20 | |
Rep 152
Can you link me the thread for the 'new' bearings? Thanks again everybody! Keep it coming! |
06-28-2015, 10:33 PM | #21 |
Rep 152
06-28-2015, 10:51 PM | #22 | |
Rep 2,301
1. change out the front and rear springs and struts especially if you've been through winters with road salt. 2. Do a professional rust block application. 3. start saving for: water pump, thermostat, radiator, and ac condenser. hit them all at once. 4. Valve Cover Gasket 5. oil change with a motor flush. I'm at 116K miles. Good luck!
'07 335I w/ Mods
'13 X1 Stock '11 X3 K&N |
