Autotalent
Go Back   BMW M3 and BMW M4 Forum > BMW F80 M3 / F82 M4 Technical Topics > Track / Autocross / Dragstrip / Driving Techniques
      06-27-2015, 02:08 PM   #1
black335i
black335i's Avatar
193
Drives: M 4
M4- Autocross impression
Tracked my M4 for the first time today.
Impression
Brakes: no fade good bite with stock pads
Transmission: left it in aggressive mode. Big mistake
You want to paddle shift the entire time the transmission
Does not hold the correct gear at times
Tires: decent but the true limitation of
The vehicle I thought. Too much power and
Not enough traction.
Power:More than enough
Suspension:Good minimal roll.good response also predictable.
Steering: responsive but lots of under steer
From crappy traction.
Overall 3.5 of 5 rating.
Recommend upgraded tires.
2008 335i- FBO
2015 M4-exterior mods, JB4 E 85
2008 Zo6- intake
2015 Honda Accord
2020 Range Rover Sport HST
      06-27-2015, 02:27 PM   #2
Andrew115
Andrew115's Avatar
328
Drives: Silver Bullet
Impression
Passive or adaptive suspension?
      06-27-2015, 03:36 PM   #3
black335i
black335i's Avatar
193
Drives: M 4
Adaptive
      06-27-2015, 04:42 PM   #4
chillindrdude
chillindrdude's Avatar
1162
Drives: anything with 4 wheels
hmm....interesting/informative observations.
i wonder if your perception of the M3/4's deficiencies would change if you were on a road course. maybe at higher speeds, the stock brakes would be the limiting factor.
i'm debating upgrading pads and fluid or more aggressive rubber (RE11, AD08R) for an upcoming DE...
My Trackable Street Car
2016 BMW M4 GTS
      06-27-2015, 06:29 PM   #5
JeffM-Houston
Drives: 2015 M3 - White/Sakir
I have to agree on the tires, I'll be switching to RE71R's next month.
      06-27-2015, 10:48 PM   #6
MaynardZed
MaynardZed's Avatar
Drives: wife crazy
Been said a bunch already, but going to HPDE or autocross is a waste of time on the stock PSS tires. Unless you're a beginner you're going to need to upgrade rubber.
Road course laptimes for BMW M4 2015 6MT
WHP East Track: 1:04.880, Arizona Motorsports Park: 1:54.352
Road course laptimes for Porsche 911 991.1 GTS 7MT
WHP East Track: 1:02.770, Arizona Motorsports Park: 1:48.889
      06-28-2015, 10:07 AM   #7
E90lova
Drives: F30 335xdrive
What about wider MPSS tires on wider rims?
      06-28-2015, 10:12 AM   #8
FTS
Enjoying driving
FTS's Avatar
Drives: 645
No doubt that no one's going to win an autox with stock MPSS tires. Or will they?
I find that with front camber, the car is behaving quite well on autox lots, and it is quite fun to get the car to rotate on the rears (steering with the rear ). I am not in the top 3 yet in the BMW CCA Tuner class, and probably won't get there, but my son is leading the Novice class thus far, so you never know
Not that it means anything, but my times thus far are better than cars in stock classes by 1 to 2 secs, but I have to run in Tuner 1 class due to camber plates, everything else is stock. We'll see how the season develops.
      07-14-2015, 10:45 AM   #9
afadeev
afadeev's Avatar
1164
Drives: F80 M3
MPSS are great for the street (quiet, grippy enough, great in the wet), but overheat easily on autoX/track. They front tires will start chunking when overheated and pushed to the limit.
YMMV,
a
'19 TM3P (BK/BK)
'15 F80 M3 (SO/SS)
ex-'17 I01 i3-BEV (PB/DD), ex-'15 I01 i3-REX, ex-E90, E46, E36's, E30's
      07-25-2015, 06:36 PM   #10
Bossdog
Bossdog's Avatar
27
Drives: 2006 Z4MR Imola Red
I just purchased my first BMW, a Z4M roadster. I have tracked and autocross in recent years. I won't be tracking the roadster but I would like to autocross a bit just to get my driving jollies. I plan to stay stock, I guess she runs in B Stock? Anyway, I think I can add the front strut tower brace and still be stock?? The BMW rims are heavy and right now they have Goodyear fun flats on, a real killjoy to drive aggressively.
My plan is to purchase some Apex Arc 8's, 18x9 / 18x10. I am considering Bridgestone RE11,s and NT05's. I know the RE11's are stalwart when it comes to autocrossing. I have run NT05's on my STi and I really liked them. Any thoughts on whether the RE11's are with an extra $50 a tire over the NT05's?
      07-25-2015, 10:49 PM   #11
EliseRR
Drives: SSP R35, SS 987 GT4, C63 Vert
OP what's your autocross experience?
I just took my m4 vert to BMWCCA event today. My car all stock with 19" rims. The car handles excellent. It is so balanced. A little understeer but if you brake enough let the car enter into corner, it is very neutral in the high speed turns. It may slide a bit but with controlled throttle steering it is very predictable. My time is about 0.5 behind those E36/E46 guys with suspension mods and better grip street tires. I had 10 years of autocross experience but my last event was 5 years ago. Note mine is convertible with 500 more lbs than Coupe. I believe M4 coupe can do a lot better.
Here is what my setting is
All sports +
Turn off traction control
Front tire pressure 39 psi
Rear tire pressure 36 psi
BTW, I found with top up, my time is at least 0.5-1 sec faster than top down
      07-26-2015, 06:43 PM   #12
black335i
black335i's Avatar
193
Drives: M 4
I have been attending auto cross events occasionally over the past 12 years when able.
I usually attend events held by http://www.texasscca.org
I am an intermediate skill level.
Thanks
2008 335i- FBO
2008 Zo6- intake
2015 Honda Accord
      07-26-2015, 11:01 PM   #13
nicknaz
nicknaz's Avatar
3189
Drives: C6Z
Aren't r comps allowed in the stock class? How about just doing those?
I read above someone has camber plates and stock tires? Going into a modified class with the combo seems really tough
      07-28-2015, 09:45 PM   #14
black335i
black335i's Avatar
193
Drives: M 4
I was in a stock class when I started
2008 335i- FBO
2008 Zo6- intake
2015 Honda Accord
f80post
