07-01-2015, 08:33 AM | #1 |
Rep 133
Music via Bluetooth on e89
Hi all.
Is there any way I can get Bluetooth to play music from my iPhone? Some aftermarket mod of some kind? I have a iPod mini hooked in via cable at the moment but what I really want is Bluetooth. Mav. |
07-01-2015, 09:07 AM | #2 | |
Rep 96
There are probably several options of that type available. |
07-01-2015, 09:21 AM | #3 |
Rep 190
My two cents:
If your car has Bluetooth for phone and not audio (like many earlier models) Then I recommend Tunelink. It is good but $$$. The earlier adapters would overheat but I think they fixed the issue. It is the ONLY model that powers up and connects automatically when you start the car. (most other adapters have an on/off button and you have to manually turn them on) The other choice would be Belkin. They offer lots of adapters. |
07-01-2015, 01:00 PM | #4 |
Rep 399
Hi
what I using in my e89 calls tune2air, I think this one best solution for bmw Bluetooth streaming Issue [IMG][/IMG] http://www.viseeostore.com/products/...-wma3000b.html |
07-02-2015, 12:51 PM | #5 |
Rep 10,509
07-02-2015, 09:12 PM | #6 |
Rep 399
07-03-2015, 12:13 AM | #7 |
Rep 244
http://www.amazon.co.uk/Belkin-Carau.../dp/B0057HUMYU
verdict is good.....Aux + BT is not that worst i brought one from e-bay, clean sound, no more hissing at high vol.....i recommended |
07-03-2015, 11:48 AM | #8 |
Rep 683
Do you have a USB port? I use my stock Apple lightning cable, the sound is better than bluetooth, it charges and I control everything with idrive.
07-06-2015, 11:56 AM | #9 |
Rep 399
07-06-2015, 04:05 PM | #10 |
Rep 683
07-06-2015, 07:55 PM | #11 |
Rep 10,509
07-07-2015, 07:56 AM | #12 |
Rep 190
The USB port alone in earlier models does not play or control music. It only charges. You have to use the Y cable that comes with the car, which plugs into both the aux port and the USB port to play or control music.
07-08-2015, 01:16 PM | #13 | |
Rep 190
12-05-2022, 04:35 PM | #14 |
Rep 1
I bought the Tune2Air WMA 3000B for my 2011 z4 and it works great! My question: can I leave the device plugged in 24/7 or should I unplug when car is parked? I'm worry about draining the battery.........
12-06-2022, 03:35 AM | #16 | |
Rep 628
Drives: E89 Atacama Yellow 35is
Compared to other OE solutions it’s poorer quality but it’s your only choice probably..
Much modified 2011 Atacama Yellow 35is…previously a much modified 2012 Atacama Yellow 20i MSport
Change history here… https://www.dropbox.com/s/8h1vabklgz...0List.pdf?dl=0 Build thread here… https://z4-forum.com/forum/viewtopic.php?t=131886 |
12-06-2022, 07:48 AM | #17 |
Rep 516
As you'll see in the photos.... It has to be the combined AUX/USB socket, not just a 12v accessory USB adaptor as it transmits the data through the OE socket
Dave
2011, E89 23i, Grey with Red leather.... relatively basic (getting less and less basic with every new retrofit)! My Z4 E89 YouTube channel... https://www.youtube.com/channel/UCtt...0vHFUQnoEvKB2Q |
12-10-2022, 09:51 PM | #18 |
Rep 6
Music
I use a USB stick that I downloaded All my music from Itunes to.
12-10-2022, 10:39 PM | #19 |
Rep 6
Blue tooth for my 2010 Z4 E89
I have an 2010 Z4 E89 and Im trying to figure out how to play music from my I phone in this car. Right now Im playing music from a usb stick that I put my music on but it's very unreliable. I wanna be able to play my music from my Iphone.
12-11-2022, 04:11 AM | #20 | |
Rep 628
If it’s the latter a lightning to usb connector should render your iPhone as an iPod as far as the E89 is concerned and should play an audio on the IPhone
Change history here… https://www.dropbox.com/s/8h1vabklgz...0List.pdf?dl=0 Build thread here… https://z4-forum.com/forum/viewtopic.php?t=131886 Last edited by B21; 12-11-2022 at 04:19 AM.. Reason: Typo |
01-18-2023, 03:03 PM | #21 |
Rep 6
I bought a Bluetooth AUX adapter from Amazon. Plugs into the 3.5mm phono socket in the centre console and works perfectly with my iPhone 13!
Mohard Car Bluetooth AUX Adapter, Mini Bluetooth 5.0 Receiver for Home Stereo/Speaker/Wired Headphones, Bluetooth Car Adapter AUX, Hands-free Calls, Dual Connection, 16H Playtime https://amzn.eu/d/ioV29r0 |
