07-01-2015, 08:54 AM | #1 |
Rep 194
Tires for 21" wheels..
I have a set of Vorsteiner wheels on the way 21x9.5 and 21x11 and am trying to figure out which tires to go with. I see the recommended size and most common here is 265/30/21 and 305/25/21. Has anyone fitted 265/35/21 and 305/30/21? The roads around here suck and I was trying to get as much rubber on them as possible without sacrificing look. Any help is much appreciated.
07-01-2015, 06:16 PM | #2 | |
212
Rep 1,385
07-02-2015, 02:34 PM | #5 |
Rep 194
Your wheel is wider than 11" in the rear to be running that tire right, probably a 12"? It looks like they are finally about to make a batch of Michelin Pilot super sports in 305/25/21, they are showing availability 8/20.
07-02-2015, 02:44 PM | #6 |
Rep 113
I went with 255 30 21 Front, 325 30 21 Rear. Michelin Pilot Super Sports. No one has tires most of the sizes are on back order.
Look into Vredestein tires, I know they come in 265 30 21 and 305 25 21. Member on here order those tires and they appear to be in stock. |
07-02-2015, 05:15 PM | #7 | |
Rep 194
07-02-2015, 07:45 PM | #9 |
Rep 288
If I knew how to post pics on here I would have shared a long time ago..... No rubbing whatsoever.. Looks really really good..... If someone know how to explain how to post pics. To a computer dummy like me I'll put up pics
07-02-2015, 07:51 PM | #10 |
Rep 288
07-04-2015, 10:47 AM | #11 | |
Rep 419
Drives: '23 BMW M8 Competition
Uploading pictures to a thread
Just click on Manage Attachments... the window on the left pops up where you Browse and Upload the picture with the max dimensions of 1600 x 1200.
CF mods from Manhart, 3D Design, Dinan, Vorsteiner and IND. Custom CF steering wheel, Custom ADV.1 510 M.V2 Advanced Series 21inch rims + titanium hardware. Carbahn Tune – 771 HP 738 lb-ft Torque, Manhart CF Intakes, Dinan CF Turbo Inlets, Keller Performance Titanium Cerakote Race Midpipes, KW Height Adjustable Spring (HAS) Kit.
07-06-2015, 12:11 PM | #12 |
Rep 113
Yes, fronts have plenty room as its a normal size but the rear is a killer. If your offset is aggressive I don't recommend running a 30 sidewall. I may have to change out the size I'm running (325 30 21). My car is still being worked on, will post final results when finished.
07-25-2015, 07:12 PM | #14 |
Rep 47
Drives: 1978 AMC Pacer Xanadu Green
I have an M6 GC with 265/30 and 295/25. I wish I would have gone wider. Any rock or pothole causes road rash. Go as wide or big as possible because it will cause damage if you don't. Just my 2 cents.
