New 2009 2010 BMW Z4 - ZPOST
Go Back   New 2009 2010 BMW Z4 - ZPOST > BMW Z4 Forum (E89) > 2009-Current Z4 Forum (E89) General Discussion
      07-26-2015, 12:25 PM   #1
paris1
Drives: 2013 35i Space Grey over Coral
Question Couple of factory warranty/service questions...
So having not yet had any factory/dealer service experience on my "new-to-me" 2013 35i, I've been watching the miles-to-service counter get closer and closer to zero and wondering exactly what the drill is. I'm assuming that as the counter approaches "0" I will get a "service required" message on the dash at which point I take it in for a free service apt. I'm also assuming that would be the time to run any issues I'm having (the car will have about 27k miles on it) and that there will be no questions asked about items like a groaning top mechanism (only apparent when the top is up, but quite annoying) at that mileage. Also, do I need to wait for the counter to get to zero, or will the dealer allow a fudge factor if I bring it in a little early and not charge me for the service?
      07-26-2015, 07:10 PM   #2
jparnes1
jparnes1's Avatar
Drives: 2016 340i, 2012 Z4 35i
What service exactly is approaching 0? Your iDrive (if you have one) will show you what's coming up. Generally you can bring it in up to 1000 miles early.
2016 340i XDrive, EBII/black, 6 MT, M Sport, Track Handling, Cold Weather, Tech, Lighting, Driver Assistance Plus.
2012 Z4 35i, ED 2/24/2012, Melbourne Red Metallic, Black Leather, Carbon Trim, 6MT, M Sport, CW, PP, PS, NAV, CA.
      07-26-2015, 07:30 PM   #3
paris1
No i-drive, so I'm not sure if I can access exactly what is coming up (or how I would do that). I'm assuming it's in need of regular periodic maintenance (lube, oil, filter) and the specifics are in BMWNA's service data base. The car has kind of a cobbled together service history as it was purchased as a CPO in January of last year, driven 7 months, traded in for a new Mercedes and then purchased by my wife and me after being serviced again by a nearby BMW dealer. So I'm not sure what it will need exactly. What about the top noise? That's covered by the bumper to bumper and isn't subject to any kind of mileage restriction for "adjustments", right?
      07-27-2015, 10:10 AM   #4
rking117
Drives: Z4 3.0i & 320i
sounds like the oil change indicator. that is the one that displays when you start the vehicle each time. And yes i would make sure you tell them about everything that you are experiencing so that they can take a look at it while you are there.
Enjoying an E89 Z4, F30 320i and Fiat Abarth //
E85 Z4 (sold), E82 128i (sold), Fiat Pop 500 (sold)
      07-27-2015, 11:42 AM   #5
nicknaz
nicknaz's Avatar
3189
Drives: C6Z
You can still use the red pixelated screen in between the gauges to see service items. You can scroll using the button at the end of the left stalk, and the little thumb switch
You can also just preemptively schedule the car for a service and dealer will figure it out when the key is read
      07-27-2015, 12:46 PM   #6
jparnes1
jparnes1's Avatar
      07-27-2015, 02:06 PM   #7
paris1
OK, maybe someone can translate from 'the high-German' for me. When I turn the ignition on I get the picture of the car and the reading is 1500 miles and the date is 10/2017. I've been ignoring the date and assuming the 1500 miles was referring to the next oil change (since we've put about 8500 miles on the car and it was serviced before we bought it. However, when I get into the service info via the left hand stalk, it shows 8000 miles to the next oil change and 10/2016. The only thing that shows 1500 miles appears to be some kind of a general service icon with a picture of the car up on a rack. Everything else (front/rear brakes, oil, etc) is way out there time and mileage- wise.
      07-27-2015, 02:49 PM   #8
nicknaz
nicknaz's Avatar
3189
Drives: C6Z
That's the service your car is asking for. I think the "high german" term for that is "Inspect I service"
http://www.bimmershops.com/bmw-inspection-1
      07-27-2015, 04:10 PM   #9
paris1
Good grief! Why do the Germans have to make everything so bloody obtuse?
For Bimmers manufactured after 1999 (excluding the '99 E36), the first Inspection 1 service is set at 30,000 and then every 60,000 miles after that, with second at 90,000, third at 150,000, and so forth.
It's a 30k mile service, which would make sense as the car has almost 28.5k on it. Of course that doesn't jibe with any of the other service readouts, but I guess overall mileage drives the schedule rather than individual service components. Thanks nick!
      07-27-2015, 04:34 PM   #10
nicknaz
nicknaz's Avatar
3189
Drives: C6Z
it's a mixture. This inspection is mileage based, but engine oil and brake pads are definitely a combo (i.e. you can hammer the brakes and require new pads sooner, or hammer the engine and require oil change sooner) but there is the once a year oil change minimum on top of that
Then for the pad sensors they can have a false alarm (i.e. extrapolate wear rates incorrectly and call for service when it isn't needed) A good example of that was my wife's 335, where I melted half the pads in a failed attempt to DE the car, and the iDrive suggested 3k miles left, but there was still 50% pad material remaining.... iDrive needed to be reprogrammed, so a service of the service internal computer was needed even though the actual service wasn't... I guess it is too old fashion just to visually inspect the pad material
zpost
