08-21-2015, 09:28 PM | #1 |
Rep 733
Suspension suggestions - ohlins or kw?
Hey,
I am trying to decide what suspension I should go with. 1. I drive the car everyday and I track it at least 1 time a month. 2. I have had H&R springs on it and currently am using the complete ground control coilover conversion kit. 3. I would PREFER to keep using the EDC or have an alternative electronic control. 4. Camber plates are a must have and height adjust-ability is a must have. Car is a competition edition if that matters, definitely prefer linear springs. Current options - 1. Ohlins R&T - good previous experience with a e92 335i - no camber plates - LOSE edc 2. Bilstein B16 Damptronic - KEEP edc - no camber plates - no reviews anywhere really 3. KW Clubsport - no edc - yes on the camber plates - not sure if it will be comfortable on street 4. any other suggestions??? |
08-21-2015, 10:14 PM | #3 |
DSC Off!
307
Rep 718
MCS 1WNR with 600/900 spring rates / Vorshlag camber plates / Apex ARC-8s with MSI studs / Stoptech Trophy ST-60/ST-40 / Cantrell Motorsports Brake Duct Kit / Cobalt Friction XR1, XR2s or PFC-11 pads / UUC Corsa axle-back with Fabspeed HFC and x-pipe / Schroth Quick Fit Pros / HANS Sport II / AA green filter / Coolshirt with large bag / Aim SoloDL with SmartyCam / CSF Radiator
08-23-2015, 01:34 PM | #5 |
Rep 3,742
I've had both the Ohlins R&T and the KW Clubsports and given your criteria, I would 100% choose the Clubsports.
The Clubsports are far better in handling, especially on the track, and yet are surprisingly comfortable on the street. I DD my car and the Clubsports are absolutely fine on my commute. As currently setup, they feel about the same as the Ohlins on 8/9, yet will handle significantly better on the track. People (including myself before I got them) expect the Clubsports to be very harsh, but they are anything but. I was very, very pleasantly surprised by their on-street performance. The only time I would recommend the Ohlins over the KWs would be for a pure street car. It is hands down the best way to lower the car while keeping OEM comfort, but the spring rates and damping are setup for comfort, not max performance. The KWs offer nearly all of the Ohlins comfort, but substantially more performance. Since you are in SoCal, I would highly recommend you take your car to MRF Engineering. Malek at MRF has a lot of experience with the Clubsport in particular and can get your car dialed. He did the Clubsports in my car and a few others that I've ridden in and the effect (dramatically improving handling without sacrificing comfort on the street) has been nothing short of voodoo magic. |
a5m623.50 |
08-23-2015, 01:45 PM | #6 |
Rep 385
I still have yet to get my CS dialed in perfectly and are, in my opinion, a little harsh on the street. Since I don't track, if I were to do it all over again, I would probably go with the Ohlins.
I think the consensus is that Ohlins are great on the street and good on the track while the CS is great on the track and good on the street. Considering how you are using the car I think the CS is the way to go.
Suck/Squeeze/Bang/Blow |
08-23-2015, 03:53 PM | #7 |
Rep 733
Thanks for the input guys, it matches up with most of the research I have done. I am waiting to hear back from anyone who has had Bilstein Damptronic or the KW DDC systems on their car. I love the ability to change dampening on the fly and would like to retain it if possible.
08-24-2015, 06:06 PM | #8 |
Rep 6,218
kw cs if you track once a month.
stiffer than stock but also compliant. where in socal are you?
08-26-2015, 04:02 AM | #10 | |
Rep 1,179
08-26-2015, 09:18 PM | #12 | ||
Rep 733
I am talking to MCS currently to see what they can offer as well. I might as well get the suspension that will make me 'faster' in the long run rather than go back and forth. |
09-16-2015, 12:16 AM | #13 | |
Supreme Allied Commander
3895
Rep 54,605
Drives: F80 M3
1. I drive the car everyday and I track it at least 1 time a month. The best daily coilover kit that doesn't give up too much on the track would be Ohlins. If you track most of the time and rarely drive on the street, then the KW CS. 2. I have had H&R springs on it and currently am using the complete ground control coilover conversion kit. Any of the above will give you a substantial increase in performance if you are only using a coilover over conversion using OE dampers and H&R springs. Ohlins will also give you a much better ride quality, better than stock actually. 3. I would PREFER to keep using the EDC or have an alternative electronic control. Bilstein would be your only choice, but you may be giving up a lot of performance to keep EDC. 4. Camber plates are a must have and height adjust-ability is a must have. Camber plates can be added to almost all coilovers. TCKR DA's is a very good alternative as well. PM, email or call us if you want to discuss anything in particular and in depth. |
09-18-2015, 04:10 PM | #14 | |
Rep 86
We just sold a set to a gentleman in Texas last week and right now their build times are really short since pre-race season hasn't hit yet. Instead of the normal 4-5 weeks we're looking at 10 days. Last edited by Casey@RWE; 09-18-2015 at 04:20 PM.. |
09-18-2015, 08:29 PM | #15 |
3895
Rep 54,605
Drives: F80 M3
MCS/Moton and JRZ also got their name in the 2-way, 3-way and pro series dampers. Both of them had many issues with their street products before getting it right.
09-19-2015, 04:46 PM | #16 | |
Rep 1,179
09-20-2015, 07:57 AM | #18 |
Rep 5,968
MCS is the way to go!
Sure custom rates are available from most damper manufacturers but they also require/recommend damper revalving (e.g., Ohlins R&T). |
09-20-2015, 12:13 PM | #19 |
Rep 1,424
I just ordered MCS singles. Their lead time is very reasonable this time of year. One week to build and ship. AR Auto Service is our local suspension guru and MCS dealer.
09-20-2015, 01:15 PM | #20 |
Rep 2,448
09-20-2015, 08:49 PM | #21 |
Rep 5,968
09-20-2015, 08:58 PM | #22 |
Rep 1,424
I think this is true. I will be running 550 front springs on the e92 M3 with singles and have been running 1000 front on the e46 M3 with triples. I don't think either were custom.
