09-15-2015, 11:06 AM | #1 |
Rep 379
Nav screen not changing to Day/Night automatically.
2015 F80 M3. I was checking the settings last night and noticed that the Nav screen does not change to the darker night mode automatically or vice versa. I have the settings set to automatically change based on the time. Anyone else have a similar problem?
09-15-2015, 11:07 AM | #2 |
Rep 2,818
Look next to your light switch and there should be a little wheel that you can adjust dash brightness with. If it's rolled all the way up and past the detent then it'll bypass the night mode. If not, check your vehicle settings and check off NIGHT MODE.
09-15-2015, 11:10 AM | #3 |
Rep 379
I'll double check it. thanks!
09-15-2015, 09:25 PM | #4 |
Rep 379
well it's working now. no idea what I did. the dimmer wasn't maxed out but I did notice it is tied to the light switch. if the lights are off no matter what time of day it is the nav screen will go to day.
