09-21-2015, 10:53 AM | #1 |
Rep 1,371
When Was Your First Brake Change?
Just wondering when everyone first had to change their front or rear brakes?
I have a 2011 with almost 40k miles and the service indicator is telling me I have about 10,000 miles until i'm due. I know the service indicator is based on driving style, but i'm trying to see when everyone else has had to change their front or rear brakes? Thanks! |
09-21-2015, 03:51 PM | #3 |
Stop the hate, get a V8
3853
Rep 8,625
I don't even know how trustworthy the CBS indicator is on the pads. I have 64k on the clock (bought with 45k) and in nearly 20k miles it has barely changed. Strangely, the rear brakes went from 12k to 6k one week but the fronts stayed the same.
I've opted to just visually inspect but am continually impressed with how slowly the pads wear. Haven't pulled out my calipers to measure disc thickness, though.
Now: 2017 Corvette Grand Sport, 2021 AMG C63 S sedan
Past: 2011.5 M3 sedan ZCP |
09-21-2015, 10:25 PM | #4 |
Rep 5,482
Iirc the sensor actually measures changes in resistance so it's not just driving style it comes into contact with the rotor pretty early and starts wearing down the little nub in the middle which I think gives it a different resistance reading the more it wears.
My fronts were still not indicating they needed changed at nearly 60k miles |
09-22-2015, 01:40 AM | #5 |
Rep 875
Changed mine at 76923. Sensor tripped. Surprisingly, I still had quite a bit of pad material left. It was actually the disc wearing below min thickness and the lip on the disc was wearing out the sensor to trip it.
09-22-2015, 06:51 AM | #6 |
Rep 1,371
Wow, the brakes do seem to last quite awhile. I've had the car for over 10k miles and the mileage to change my brakes haven't changed.
09-22-2015, 12:07 PM | #7 |
Rep 1,470
2000 miles when I took them off and installed a BBK.
Stoptech 380mm/355mm | PFC08 / Pagid RS-29 | Akrapovic EVO - CF tips | Benvo Tune | MS UDP | AA air filter | MCS 2-way with 700/1000lb springs | Solid bushings and adjustable links | RD front swaybar | Apex EC-7 18x10 square 275/35-18 NT01 | Turner Race Studs | GT4 Brake Cooling | GT4 Power Steering Cooling | Alekshop Oil Cooler | Performance Steering Wheel | | CF Spoiler | Varis System 1 Full CF Diffuser | Extended Paddle Shifters | Schroth Quick Fit Pro | Turner Steering Rack Stops | Vorshlag Camber Plates
09-22-2015, 06:41 PM | #8 |
Rep 473
89k... original rotors (28.7mm), a handful of track days (Not experienced enough to push it to the cars' limits yet). Changed brake pads to some street/track pads (didn't measure but were thicker than my stock pads) and am back on stock pads with a bit over 4mm (need to get this under 4mm for a brake pad/rotor swap before 100k).
2011 e92 JzB 6MT
Akrapovic Evolution, ESS Tune, KW V3 |
09-22-2015, 07:02 PM | #9 |
Rep 1,371
Amazed by the longevity of the stock brakes.
09-22-2015, 11:04 PM | #11 |
11818
Rep 23,187
Ah I remember it well it was the summer of 82 i was 11 years old. My dad gave me a pack of menthols and the promise of an ass whooping if I didn't change the pads on his 78 k10 blazer...
09-23-2015, 12:57 AM | #12 |
997.1TT
1010
Rep 1,672
I am still showing 28k km on mine and the car has 50k miles. bought it at 43k miles last Nov. I wonder if my pads have been changed before? Nearly 70k miles seems a lot for oem pads.
07-06-2018, 10:20 AM | #14 |
Rep 88
Drives: 2011 BMW E90 M3, SilverstoneII
I realize I'm late to the party here, but I have a 2011 E90 M3 that I call my daily, but I don't drive her, every day.
I'm trying to understand why my rear brakes need replacement after less than 12000Km. Front brakes are still showing 25000km until next service in iDrive. My driving style is spirited, but these pads and rotors have never seen a track. There must be something wrong. I replaced the brakes a little less than a year ago on both axles, because the rears were crying and the sensor had gone off for the back, so I did all 4 corners. Now the rears are crying again and the sensor has gone off too and it hasn't been long enough in my opinion. Plus, why just the back and not the front, second time in a row? I haven't broken out my calipers, but now that the audible is making an appearance and the sensor is recommending service in iDrive, I don't think think it's necessary to measure. I need to replace, but I'd like to know why this is happening, so I can avoid unnecessary wear in the future. I feel like the rear pads are wearing out way too fast! Help? |
07-06-2018, 11:39 AM | #15 |
1967
Rep 1,927
Drives: E92 M3
Are you using the original pads and rotors? Measure the pads and rotors to see if they really need replacing. CBS isn't always accurate when it comes to spirited or track driving.
07-06-2018, 11:46 AM | #16 |
Rep 1,566
I changed front and rear rotors and pads at 64k miles. I probably could've gone another 10-20k more but wanted to get it out of the way.
