09-22-2015, 05:43 PM | #1 |
Rep 3
245/35-18 Front Fitment Stock?
I really need some first hand experience trying to fit a 245/35-18 on the FRONT of a stock height msport 135i. IVe found substantial evidence thatI can fit a 265/35 on the rear but no conclusive evidence on how to fit the front tire. Im willing to pull the alignment pins now, but i dont have the cash to do M3 arms or camber plates in conjunction with the wheels and tires.
The combo im looking to try is below: VMR V810 18" Front: ET 45 or 40 245/35 Michelin PSS Rear ET58 265/35 Michelin PSS Any propt help is greatly appreciated as i have a blown wheel and tire and no car to drive at the moment, so i need to get things ordered fast! |
09-22-2015, 09:01 PM | #2 |
Rep 66
I have found a few examples, but unsure if the ones that needed fender work were lowered. I would like to hear from others as well.
Here is a good example http://www.1addicts.com/forums/showthread.php?t=636422 |
09-22-2015, 10:11 PM | #4 |
Rep 66
09-22-2015, 10:26 PM | #5 |
Rep 403
I'm running 245/35R18 RE050A RFT tires front and back, on a set of square 18x8.5 ET52 Style 264s with 10mm spacers (ET42 effective).
Stock fenders (no rolling). Front camber is -2.2° No-rub... See http://www.1addicts.com/forums/showthread.php?t=1170959 Karl.
Stock – 997.2 C2S Coupé • Carrara White / Cocoa • Adaptive Sports Seats • PDK w/SC • PSE
Mods – Front 996-GT2 and Rear 997-Turbo Brake Ducts • 3rd (center) Coolant Radiator • 10mm/15mm Spacers Last edited by wjk_glynn; 09-24-2015 at 11:01 PM.. |
09-24-2015, 08:02 PM | #6 |
Rep 25,988
You'll definitely need to do a bit of camber adjustment. The recommended tire size is 225/40 245-255/30 based on stock to mildly lowered. Rolled fenders, and some camber should get you there.
VMR|Wheels | 714.442.7916 |
sales@velocitymotoring.com | www.velocitymotoring.com | facebook | flickr | Instagram |
09-28-2015, 10:15 AM | #7 | |
Rep 750
Drives: '98 Z3M (gone), '09 135i
I probably would have been able to fit a 245 PSS tire fairly easily without modifications |
