BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > E90/E92 M3 Technical Topics > Suspension | Brakes | Chassis
Mporium BMW
      09-25-2015, 04:02 PM   #1
petrolheed
Drives: E92 M3
e92 M3 track handling improvements
I have an e92 M3 specifically bought for track use. I wont use this car on road.
I have installed KW Clubsport 3 ways, 265/295 18" tyres and made some slight weight savings.
I really do not like the way it handles. The body roll is terrible and there not much steering feedback.
I am looking for suggestions of ways to significantly improve the car with reversible items as if I still don't like it Im going to sell.
Thanks.
eta. I drove a friends CSL on track which at the time had a 'lesser' suspension and I immediately felt comfortable and in the zone.
      09-26-2015, 03:43 PM   #2
Arben
Dunce Cap
Arben's Avatar
Drives: '12 E92 M
Suspension needs more tuning. Get some sway bars and a square set of 285 tires, staggered on a track isn't as nice.
      09-28-2015, 11:37 PM   #3
Longboarder
Longboarder's Avatar
3437
Drives: 2016 BMW i8
Bro you need to call a shop that specializes in racing e92 M3's.
Current BMWs: 2022 X5 40i, 2016 X5 50i
2015 Porsche 991 Turbo S
1979 Porsche 911 Turbo (930)
a couple others
IG: longboarder949; YouTube: https://www.youtube.com/channel/UCT1...eoFBszPIK0gf9w
      09-29-2015, 12:24 AM   #4
AriuSen
AriuSen's Avatar
Drives: Z4M Coupe
^^^^^ this
suspension tuning wont matter on your body roll much like sway bars... thats wat you need. front and rear. dont add just front. I have it like this and it understeers too much.
also go square, but with nitto nt05 or maxxis rc1. those will also help a little on body roll.
i was also on the fence to change to an e46, but I am stubborn and I wanna try to make my e92 very enjoyable at the track.
Instagram: ariusen26
Youtube: Track vids
      09-29-2015, 12:32 AM   #5
1MOREMOD
1MOREMOD's Avatar
Drives: Race car->
What spring rates. Car is heavy it will tend to roll more.
      09-29-2015, 08:46 AM   #6
doogee
doogee's Avatar
749
Drives: '08 M3, '09 328xi Sport Wagon
Tires have no effect on body roll.
      09-29-2015, 08:54 AM   #7
lutfy
lutfy's Avatar
255
Drives: G87 M2, NASA ST5 86, Defender
Thanks.
Too many variables at play to answer. Call up Geoff Steele (they build the finest track cars in the UK) and are somewhat closer to you (to build relationship with). There should be NO way the car should behave the way you have described with the hardware you have (alignment, height, shock setting... all comes into play).
Cheers,
Lutfy
      09-29-2015, 12:58 PM   #8
Malek@MRF
BimmerPost Supporting Vendor
Malek@MRF's Avatar
Drives: E92 M3, E46 M3, G82 M4
Thanks.
If you went stagger and removed weight from the rear, the car isn't going to handle as well as you expect. (I am assuming the weight was removed from the rear)
BMW PERFORMANCE SPECIALISTS. Race Engines. Suspension. F/I. Brakes. Race Preparation. Factory Service. Alignments.
OFFICIAL PARTNERS: KW. MOTON. Brembo. AP Racing. BBS Motorsport. iND. HRE. Turner Motorsport. VAC. BMW Motorsport.
Facebook | Instagram | Yelp! | Flikr
Phone: 949-233-0448 | E-Mail: info@mrfengineering.com
      09-29-2015, 03:45 PM   #9
petrolheed
Drives: E92 M3
Sway bars are what I had suspected I would need to improve things. I dont believe I need 285's on the front - Schrimer (Germany) are building some of the fastest cars at the Ring (Nurburgring) just now and they run 265/295 on 10/11" wheels.
^^^^^ this
Research I have done says the rear isn't worth bothering with but you reckon its worth doing both?
Standard spring rate that the Clubsports come with - 110Nm front and 120Nm rear plus helpers.
Cheers,
Lutfy
I'll make a point of contact with them to see what they can suggest but I mainly find these boys want your car and a blank cheque, whereas I like to build the car myself (not that thats working out well!)
Weight saved is mainly from interior - rears seats removed and all the rubbish in boot as well as front seats removed and replaced with SPG's. Weigh in around 1540kg.
m3post
