10-10-2015, 09:54 AM | #1 |
Rep 164
Drives: 2016 M4 Convertible
My BMW Remote: "No Internet connection" (Android)
I have the Android version of My BMW Remote. It has worked intermittently in the past, but whenever I try to do anything (headlight flash, lock, etc.) it errors out and says "No Internet connection available for your smartphone". Obviously that's not correct, it's connected fine and every other app, web browsing, etc. works just fine.
Has this happened to anybody else? Any known fix? I have uninstalled and reinstalled the app several times but didn't help. I contacted the Genius line and they verified the account was OK and submitted a support case but didn't have any info other than that.
2016 M4 Convertible: Tanzanite Blue, 6MT delivered 9/2/2015
10-12-2015, 04:31 PM | #3 | |
Rep 164
10-12-2015, 05:31 PM | #4 |
Rep 482
Drives: 2015 F82
Constant problem for me as well on the android version. I have an iPhone as well with the app on it and it appears to work a bit better, but it is still a bit flakey. Garbage App Dev's...
10-13-2015, 12:42 PM | #5 | |
Rep 2,009
Having the same problem on my S6 trying to send a signal to vent the car. The app is garbage |
10-16-2015, 11:04 PM | #6 |
Rep 164
So they got back to me about my support case. The Genius guy initially agreed with me it's probably a bug in the app (or, he said, maybe my Android version is too new (5.1.1)). Then he called back a few days later and said he'd heard back from the developers. They advised "Uninstall and reinstall the app, then use the car menus to Update BMW Assist." if it still doesn't work take it to the dealer.
WTF? It took the dealer two days just to fix Connected Drive when there was already a service bulletin for it. I can't believe the dealer cares or wants to deal with an obscure Android app bug. I guess it's possible the problem is with the car, but the app instantly complains about the Internet connection on the phone. It's not like it fails while trying to talk to the car.
10-28-2015, 06:55 PM | #7 |
Rep 164
Anyone else have a recent update? It's been working slightly better for me... I've been able to send map positions to the car a few times, flash headlights, honk horn, but today it's refusing to work again. Same error, "No Internet connection for your smartphone". I still think it would be a waste of time to take the car into the dealer for this. Maybe at my next regular service I'll ask about it if there's no fix by then.
10-29-2015, 12:23 PM | #8 |
Rep 2,846
I downloaded the android app and get message "No activated services, please contact BMW Assist for further support', does this mean by BMW assist is not activated?
2 days back i had issues with SOS button in the car and then had spoken to BMW Assist and they confirmed my services are activated. How to address this ? Whom to contact?
2021 M2C HS/6MT/Exec/Moonroof
10-29-2015, 12:25 PM | #9 |
Rep 164
Yes I believe this means you need to activate. In my case I recall it took several days after activation until the app started working so you may want to wait a few days if they just activated it.
10-29-2015, 12:59 PM | #10 | |
Rep 2,846
For me the problem started when i pressed SOS button in the car last tuesday and the representative told me they were not getting signals from my car and asked me to try again and after he hung up my system was frozen for 30 mins showing message " transmitting data etc". during that time idrive did not work . I called BMW assist from my phone and they told me dealer needs to submit ESA to BMW to activate service and had the dealer submit that and BMW assist called and confirmed the services are activated. I am yet to try hitting the SOS button and check if its working
10-29-2015, 01:07 PM | #11 | |
Rep 164
One of the funny things the people on the Genius line told me was that they were surprised I was having trouble with the Android app; they said it was "very reliable" and the iOS app was the one constantly causing problems for users!
10-30-2015, 06:55 PM | #12 | |
Rep 482
Drives: 2015 F82
11-05-2015, 09:47 PM | #13 |
Rep 164
BMW released a new version of the Android app yesterday. Version "4.0.0.US". It has a minor UI redesign with new icons, colors, etc. Also they dropped "My" from the name and now it's just named "BMW Remote".
Most importantly, I haven't seen any errors since I installed the app. The "No Internet connection" error seems to be gone. Fingers crossed, I'll keep my eye on it!
11-05-2015, 09:50 PM | #14 | |
Rep 482
Drives: 2015 F82
Things seem to be running a bit smoother for me as well. Sending address info just fine to the vehicle (slight delay) and none of those pesky I-Net connection messages as you said. |
11-06-2015, 06:59 AM | #15 |
Rep 595
Always try to connect for the first time. It will tell you there is no connection. Wait a few seconds for the server to send a signal to your car. After a Minute or so your car will be visible and then you can connect.
Try that. It always works for me. |
11-06-2015, 10:44 AM | #16 | |
Rep 164
However, I just confirmed after reading reviews on the Play store: they removed the ability to share addresses from other apps. E.g. if you have an address in Google Maps or other app and choose "share", BMW Remote no longer shows up in the list of apps you can share to. Which totally sucks, because now you have to use their map interface to search for addresses.
11-06-2015, 12:02 PM | #17 | ||
Rep 595
11-07-2015, 01:11 AM | #18 | |||
Rep 164
11-07-2015, 06:32 AM | #19 | ||||
Rep 595
11-08-2015, 09:09 AM | #20 |
Rep 164
The problem we're talking about is if you are in a different app like Maps and choose to Share an address, BMW Remote no longer shows up in the list of target apps. This forces you to use the BMW Remote built in search to find destinations instead of sharing from Maps, your email, etc., which is much more convenient.
11-08-2015, 03:03 PM | #21 | |
Rep 482
Drives: 2015 F82
