10-21-2015, 07:24 AM | #1 |
Rep 59
Tools on how to remove and install plastic rivets to change fenders
Hi guys,
Just wondering how you would remove the plastic rivets under the fender arch? I will be upgrading my fenders to carbon fibre ones. ? I've seen a few ways: 1. Drilling into the centre of the river 2. Pushing and punching a hole into the centre of the rivet then pulling it all out 3. Pulling the river out completely Does anyone know what the safest and easiest way is to remove the rivets? Also I believe you require a special tool to install plastic rivets. Can anyone suggest what tool is required for our F15 X5? Below is a picture of what rivets are. |
10-21-2015, 08:14 AM | #2 |
Rep 660
This is what you need to install the rivets. Also keep in mind they are not reusable so once you break the old ones off you will need to install new rivets. And make sure you order white rivets as opposed to black as that is what is installed on your car now.
http://www.justforjeeps.com/rivetgun...FU82gQodZ1cDQg |
10-21-2015, 08:44 AM | #3 |
Rep 18,785
@dislodge1 , you used drill or punch to remove the rivet.
Then you can use that tool, or 2 plier to secure the new rivets. One with the hole in the middle to hold the rivets in place and the other one to pull. I have been doing it that and it works perfect.
10-21-2015, 10:34 AM | #4 |
Rep 1,181
No need to buy a special tool. Just do what Ben suggested. Drill out the middle post in two seconds and the rivet falls out. Install a new one by holding down the flat circle with a pair of pliers or a notched trim removal tool while pulling up on the center pin with some needle-nose pliers.
These rivets are akin to wall anchors you'd use at home. Once you pull on the center pin, it deforms/accordians the hollow sheath, locking the rivet in place. Adding a couple pics. Hopefully they're not huge (using the app)...
A little mod here, a little mod there...
10-22-2015, 06:54 AM | #5 |
Rep 59
Hi guys,
Thanks for the friendly advice. Yes I was looking at the tool. So I guess I can get away without having to purchase tools! I see so you actually pull out the center pole out from the river itself.. I always thought that rivet gun actually pushes the pole inside rather than pulling it out completely. So just to confirm I can just use a plier to pull out the centre pole? And I use another plier to hold it in place? Here is a picture of the carbon fibre fender I am getting. Anyone here have any thoughts on this type of fender? |
10-22-2015, 07:10 AM | #6 |
Rep 34
I have removed these rivets. The best and easy way is to drill out the centre part. What this does is melt/cut through the centre part, keeping the whole rivet in one piece. Then you use needle nose pliers to pull the whole thing out. If you use a punch, the centre part drops down on the inside and you can't remove, it rattles around inside the fender. Drill gives clean job. Note: For the rear you will need to remove the tyre to make room for the drill?
10-22-2015, 10:54 AM | #7 |
Rep 2,995
you can buy a rivet gun real cheap at harbor freight. see if you have a store nearby.
http://www.harborfreight.com/ |
11-03-2015, 05:27 AM | #10 | |
Rep 59
11-03-2015, 09:48 AM | #11 |
Rep 18,785
@dislodge1 , you need to remove the tires to have more room to work.
11-03-2015, 10:42 AM | #12 |
Rep 598
I didn't have to remove the tire to drill out the rivet. And I used a regular sized drill and drill bit. You have to go at a little bit of an angle, but it was never tight enough for me to even think about taking the tire off. But you will have to see what works for you
11-03-2015, 02:16 PM | #13 |
Rep 1,547
You don't HAVE TO remove it, but it does make it easier.
2014 BMW X5 xDrive 35d M Sport Mineral White
2011 BMW 135i M Sport Space Grey 2007 Suzuki GSX-R 750 |
11-03-2015, 02:18 PM | #14 |
Rep 5,066
What was the pricing on the mirror caps and is the pattern similar to the BMW OEM parts?
2015 F15 X5 35i Msport Space Grey M Performance parts MPPK, MPE
11-03-2015, 05:14 PM | #15 |
Rep 1,015
At first I thought, thats not going to look so good, but was just checking out auto fans website. The white x5 with carbon front splitter, wheel wells, side ground effects and rear with black wheels looks nice!
Anybody buy the front splitter yet? |
11-03-2015, 09:32 PM | #16 | |
Rep 59
Haven't installed them yet but I'll post some pics of it once I get the chance to install them |
11-03-2015, 09:36 PM | #17 | |
Rep 59
11-03-2015, 11:14 PM | #19 |
Rep 1,181
Obviously making life easier for yourself by removing the wheel is the best, but you could remove the rivets by using a center punch to push the pin in, which would also release the anchor. Again, you'd have to get a punch that was short enough for the space.
Whatever you choose, hurry up! We want to see the installed pics!!!
11-04-2015, 09:31 AM | #20 |
Rep 5,066
I'm looking forward to the pics as well... The quality looks to be okay but on the side mirror caps I can see some weaves that seem to be misaligned, maybe on some batches they are flawless.. Who knows.
The front lip looks pretty good based on the pics and the price is outstanding! twelve535i & aw305 you guys want to try them out? http://cnautofans.com/products/carbo...-0395-677.html
11-04-2015, 09:48 AM | #21 |
Rep 598
Yes, I did both rears without having to remove the tires. In fact I ONLY did the rears, as I had to remove the trim pieces when I installed my trailer hitch. The thought of jacking the car up and/or removing the wheel never even occurred to me. The rivets just drilled right out. You may want to try a couple before taking off the tires. pretty easy, and you will know immediately whether you think you need more room.
11-04-2015, 09:49 AM | #22 |
Rep 1,363
Kzang I've seen their ebay listing and stumbled upon their website about a week ago. The fitment on the front lip didn't look perfect but acceptable for more than 1/2 the price. The rear diffuser and cap looked good also so I sent them an email asking about fitment. I was told the front lip and rear diffuser don't fit well, which is not good news for me, but at least she was honest.
