10-23-2015, 06:28 PM | #1 |
BimmerPost Supporting Vendor
9607
Rep 10,891
Lowering spring comparison from IND.
The F8x M’s in-cabin adjustable dampers provide a tremendous range of driving experiences, and can transform the car from comfortable to sporty at the push of a button. Although most springs are a lateral move at best from a performance standpoint, many M owners choose to add lowering springs for a simple, low cost solution of lowering their car and simultaneously retaining the original BMW damping adjustment. In order to shed some more light on the myriad of available spring options, we’ve created a simple comparison of each. IND has each type of spring in stock and measured the overall length, coil count, and coil diameter of each spring. We also tested the spring rate of each on Fall Line’s spring rate tester, to see what the actual measured rate is. A few notes:
10-23-2015, 06:48 PM | #4 |
Rep 560
are eibach's numbers reversed for F and R..wouldnt R be super low then given that it is already lower than the front?
but this is very helpful..too bad we cant see actual compression/spring rates stats |
10-24-2015, 11:36 AM | #8 |
Rep 20,742
Drives: 2021 911 turbo
Very informative post as usual. You guys are great contributors to the forum .
Porsche 911 turbo 2021 992 GT Silver
Previous cars: M4cs 2019 F82 Limerock Grey / M4 2015 F82 Silverstone / M3 2008 E92 Silverstone / M3 2002 E46 Carbon Black |
10-26-2015, 04:59 AM | #11 |
Rep 656
///M4 | AKRA Evo & DP's | Brembo GT BBK | MSR CAI & CP's | MPSC2 |
Suspension : | KW CS 3-way | Dinan Toe Links | GC ARWJ & End links | IND Shims | SPL Control arms & End links | aFe Bars | |
10-29-2015, 12:09 PM | #12 |
Rep 138
Drives: 2016 M4
I dont think IND carries those brands.
11-11-2015, 12:39 PM | #14 |
Rep 43
What is the diameter of the KW HAS front springs? Trying to figure out for the right GC camber plates.
Thanks,
11 GT3 RS
15 F80 M3 6spd 99 E36 M3 |
11-18-2015, 03:47 PM | #15 |
In Hoc
315
Rep 626
Drives: 2016 M4 6MT MG/SO
What happened to Swift in the list?
2016 M4 MG/SO 6MT- Max PSI Intakes - BMS Stage 1 - Swift Spec R - CG Precision Valve controller - 20" DPE Flowtech 5S - AA Midpipe & all the external CF goodies.
