11-03-2015, 06:02 PM | #1 |
Rep 3,039
CCB Noise Remedy List
I want to start a thread with things people have tried to reduce the noise from the CCBs. Also I'd like for everyone who doesnt have noise to chime in. Add Number of track days also.
I'll go first. FYI I had 0 brake noise before taking my car to the track... Track days: 3 Noise: High Pitched squeal during normal braking, some squeal during slight steering inputs Remedy 1: (Unsucessful) BMW Dealer Lubed the rotors Remedy 2: A local race shop is going to try applying caliper grease to some of the pad fittings and an adhesive for the back of the brake pad to the caliper pistons. This didnt work! Remedy 3: WORKED! Retrofit Porsche anti-rattle discs into the caliper pistons. Cut down on noise by at least 75% I'm very happy so far with the result, and the discs fit pretty perfectly. Last edited by CSanto; 01-17-2016 at 09:41 AM.. |
11-07-2015, 08:27 AM | #3 |
Rep 296
i drive around wearing these:
The noise does get annoying at times in stop and go traffic if the brakes are still cold. I've tried a couple of runs going from 40-0mph to warm them up a bit and that has helped somewhat. |
11-08-2015, 09:45 AM | #6 | |
Rep 3,039
An indy shop near me greased all the fittings. It still squeals pretty badly. More so when im not even braking. I had no squeal before tracking the car. My theory is that once i tracked the car i ate away at some of the thickness of the brake pad. This caused movement of the pad in the caliper and thats whats causing the problem. |
11-08-2015, 09:46 AM | #7 | |
Rep 3,039
I may have to buy new pads for the street and swap them for track season. |
11-10-2015, 07:40 PM | #8 |
Rep 331
Never tracked...but with steering inputs to left, relieve high pitched whine from front right wheel area. Occurs at low and high speeds. Only when I turn left and noise comes from front right. But will occur at highway speeds while accelerating too. Have a video of me going 50-60mph and the squeak is very constant.
Will try noise sound canceling headphones to see if that works next...ugh
__________________________________________
SOLD: 2015 M4 coupe Tanzanite Blue/Full Black/Black 19s/CCBs/6MT |
11-10-2015, 08:01 PM | #9 | |
Rep 3,039
My shop used ceramic grease on all the fittings. Initially it made no difference but now i have no noise during braking which is an improvement. I still have the noise youre describing. It's simply the pad moving around in the caliper housing. |
11-10-2015, 08:05 PM | #10 |
Rep 331
And there is no remedy?
Seems like even strong stops from high speed don't help either. Weird that it only happens when I turn left and only front right. Why not when I turn right and from the front left?
11-10-2015, 08:15 PM | #11 | |
Rep 3,039
Once i tracked the car and wore down some of the pad there was more play and room for vibration. |
11-10-2015, 10:17 PM | #12 |
Rep 331
Dealership just replaced front pads and didn't make a difference. Squealing is still there. Perhaps something different not related to CCBs?
11-10-2015, 10:42 PM | #13 | |
Rep 3,039
11-12-2015, 01:34 PM | #14 |
Rep 331
Video of noise coming from front right...
BMW has opened up a "PUMA" case regarding this but initially wanted to chalk it up to CCB expected noise. I'll try to upload in better definition but invisibly squeak can be heard at 50-60mph
11-12-2015, 04:52 PM | #15 | |
Rep 3,039
I was told that the main reason for noise is that the Ms dont use what Porsche calls anti rattle discs. You push them into the pistons first, then peel off the backing paper to expose the adhesive, then drop the pad in place and press on the brake pedal, to make them adhere to the pads. We need to find the diameter of the MCCB pistons. Porsche makes these discs in almost every size. |
M 4 FUN607.50 |
01-14-2016, 03:03 PM | #17 | |
Rep 761
01-14-2016, 03:45 PM | #18 | ||
Rep 3,039
I bought the parts from Paragon products. I installed the discs on one front caliper for testing, they snapped right into the pistons. I'm doing the other 3 saturday, and will report back. Note: It's COLD so theres going to be more noise than usual regardless, im still hoping this eliminates 75% of the noise. |
01-14-2016, 03:50 PM | #19 | |
Rep 3,039
30mm 34mm 36mm So since theres 6 pistons on each front caliper you need 2 of each diameter per corner. Rear Piston Diameter 28mm on all 4 So you need 8 28mm discs. It's not cheap, this "fix" (if it works) will have cost me $204 in parts, and about $400 in labor. Like I said we shall see on Saturday. |
01-14-2016, 05:45 PM | #20 |
#LSBM3
1424
Rep 1,973
Drives: 2016 BMW M3
Garage List 1984 BMW R65 [0.00]
2020 Ford F-150 XLT ... [0.00] 2003 Mitsubishi Evo ... [0.00] 2016 M3 Competition ... [10.00] |
Subscribing.
/// M3 |
01-14-2016, 06:32 PM | #21 | |
Rep 761
Any idea what the piston sizes are for the steel brakes? |
01-14-2016, 06:39 PM | #22 | |
Rep 761
https://www.ecstuning.com/ES1458693/ |
