11-10-2015, 08:19 PM | #1 |
Rep 7
Offsets - Will they Fit?
Hello
I'm an extremely new BMW owner and was looking at ordering a set of brand new work wheels - just need to confirm the offsets and sizes I'm after will fit with stock suspension as well as coilovers when i lower it. Im going to roll the guards but want to stay away from pumping/flaring. 2010 123d Coupe currently have BMW 313 wheels Option 1: fronts 18x8.5 +39 with 225/40r18 rears 18x9.5 +52 with 255/35r18 Option 2: fronts 18x8.5 +39 with 225/40r18 rears 18x9.5 +45 with 245/35r18 If anyone is running these sizes it would be amazing if you could share pictures Thank you in advance Last edited by Am91; 11-11-2015 at 02:08 AM.. |
11-11-2015, 09:11 AM | #3 |
Rep 2,040
Drives: 2008 135 blk, blk, step
Garage List 1994 Porsche 968 Cab [0.00]
2017 AMG GTS [0.00] 1994 Porsche 968 Coupe [0.00] 1977 Mercedes 450SE ... [0.00] 2008 135 [8.00] |
Fronts should work with most non R tire brands. Could rub a little when the suspension compresses or if you go too low. For the rears, option 1 is best. Option 2 will work depending on tire brand, how much you lower, etc. If it does rub more than you want, you could add more camber. Option 3 would be difficult.
Injen, RR OCC, MadDad Whisper, donut spare, 19x8.5et43fr 19x9.5et45r Volk LE37's, rear fenders rolled/pulled, PSS4S 225/35fr 255/30r, KW V1's, AR coated catless dps, Cross strutbar, CF grills and license plate holder, iCarbon diffuser, ETS black anodized FMIC, M3 control arms, Quaife, ER chargepipe, ForgeDV's, Topspeed Custom Tune, V3sims, Braille, Andrey_GTA rear hub mod, Ebay Mstyle front bumper and performance style side skirts.
11-11-2015, 10:31 AM | #4 |
Rep 3,141
Drives: 2014 M5 6MT
Option 1 will work the best. Little to no chance of rub on the back and plenty of clearance up front.
2014 M5 6MT
11-11-2015, 06:42 PM | #6 |
Rep 3,141
Drives: 2014 M5 6MT
Mine is close.
18X8J ET40 with 225/40-18 Federal 595RSR ( 241mm wide, same as a 245/35 Michelin PSS) 18X9J ET45 with 245/35-18 Federal 595RSR (253mm wide, wider than my 255/35-18 MPSS.) Rear fenders had to be rolled. If you are running a ET52 wheel on the back, no fender mods will be needed.
2014 M5 6MT
11-12-2015, 02:28 PM | #7 | |
Rep 7
11-12-2015, 02:47 PM | #8 |
Rep 3,141
Drives: 2014 M5 6MT
yes, IM on coilovers. The exact amount Im lowered I don't know. I had the car corner balanced when the coilovers were installed. But it's alot lower than stock and zero rubbing.
2014 M5 6MT
11-12-2015, 10:12 PM | #9 |
Member.
201
Rep 827
If you're trying to stay conservative, option 1 would be ideal. The 39ET in the front is a little most aggressive than the 313s, but you shouldn't really have a problem.
11-15-2015, 02:54 AM | #11 |
Rep 7
I test fit 18x8.5 +42 front 18x9.5 +45 rear and it sat well with stock suspension. If I went +45 all round would this be ok with stock suspension and be compatible when I lower it ?
11-15-2015, 10:52 PM | #12 |
Rep 361
It will depend on your tire and rear alignment.
I am running a 255 RE71R which is a wide 255 on a 9" +45 rear wheel with -2 degrees camber, and it does not rub during street driving, but does rub during extreme autocross use. "tphaeng" reports no rubbing with 9.5" +40 offset with 255s which does not seem likely to me - his wheel sticks out 11.5mm more than mine. For my setup to rub under autocross and his to not, it would only be possible is if he is running a bunch more rear camber (like -2.5 minimum or has a super narrower 255). The photo above looks like the tire is a bit narrow as it appears to be stretched, but frankly it does not look like it would clear under even moderate cornering. To your question, a 9.5 +45 will only fit with a 255 if you have over -2 degrees of camber and a narrow tire. Otherwise you will require -2.5 or more camber to clear it under ALL circumstances. Mark
2011 BMW 128i - Check out my STX build thread!
11-17-2015, 04:22 PM | #13 | |
Rep 966
