12-15-2015, 05:56 PM | #1 |
Captain Fatbelly
1423
Rep 1,994
High rpm hesitation
I am experiencing a sporadic issue that is starting to worry me. On a hard romp the car will hesitate a couple times between 7 and 8k rpm. Feels like a misfire problem I experienced in my last supra where the spark would blow out past 18 lbs of boost if the gap was too wide....however I put in new plugs at stock gaps in June and I am not FI. I thought maybe bad gas but I've been through 3 tanks, from 2 different shells. No codes. The only change I have made to the car recently is going from 5w40 to 5w50. Doubt that could be related but who knows? Anyone have any ideas?
2013 c63 Amg coupe p31, v7 tune, plm headers, armytrix downpipes, EflexFuel
2008 dct coupe, evolve engine/dct tune, ttp, ms intake, megan exhaust, cf ds. Sold. |
12-15-2015, 07:42 PM | #2 |
BimmerPost Supporting Vendor
3392
Rep 7,544
Perhaps an intermittent coil, or fueling issue.
-----| Like us on Facebook | Instagram || Tuning Information | Remote Coding |----- ----Visit us at www.BPMSport.com - Emotion. Driven. | Toll Free: (888) 557-5133---- |
12-15-2015, 07:52 PM | #3 |
Captain Fatbelly
1423
Rep 1,994
Thanks. I did some more testing tonight and it doesn't happen in first and second at all but does in 3 and 4. Not sure if that is pertinent? Any way to trace down a dying coil?
12-15-2015, 10:19 PM | #4 | |
Rep 1,178
This is very dangerous as your rear brake lights will not turn on while your car looses speed like light to moderate braking. On the good side, if this is caused by RB spinning and recovering and your engine finally seizes a lawsuit like this would be undefendable by bmw and they would have to do sth about RBs. Last edited by Rajmun340; 12-15-2015 at 10:24 PM.. |
12-16-2015, 04:35 AM | #5 |
Rep 1,017
Drives: 2010 E92 M3 6MT
Had this starting to happen in my truck, was coil packs going bad. Did have some loss of power when I romped on it in the M but that was from Spark plugs and cleared up soon as I changed them.
4.4L LC stroker/ESS VT2-625/Volk te37 sl's/AA exhaust/DSS Carbon Fiber driveshaft/ARH Headers.. etc |
12-16-2015, 07:34 AM | #6 |
Rep 6,771
Drives: 2016 BMW i8
Garage List 2012 BMW e92 M3 [0.00]
2021 BMW X5M [10.00] 2015 Porsche 991 Tu ... [10.00] 2015 Porsche 991 GT3 [10.00] |
There is more load is the upper gears so that's why it can happen in 3rd/4th and you don't feel it in 1st/2nd. Any way you can get a data logger? Or maybe go to a dyno that can read your vitals?
Current BMWs: 2022 X5 40i, 2016 X5 50i
2015 Porsche 991 Turbo S 1979 Porsche 911 Turbo (930) a couple others IG: longboarder949; YouTube: https://www.youtube.com/channel/UCT1...eoFBszPIK0gf9w |
12-16-2015, 09:09 AM | #8 |
Captain Fatbelly
1423
Rep 1,994
Good ideas....any suggestions on a data logger? Thanks
12-16-2015, 09:23 AM | #9 |
Captain Fatbelly
1423
Rep 1,994
That's what I keep telling myself....really seems ignition/fuel related, but in the back of my head I keep thinking about ARP bolts and bore distortion.....and I'm sure I've read here that high rpm's also have an effect on bore round. However the hesitations are not happening in any predictable manner that would coincide with an engine stroke.
12-16-2015, 09:29 AM | #10 |
Captain Fatbelly
1423
Rep 1,994
If it matters when I changed plugs I used the ngk's, not BMW.
12-16-2015, 10:09 AM | #11 |
145
Rep 170
That is typical for a bad plug but it sounds like a bad coil or fuel delivery issue if you just recently replaced plugs. That RPM and gear is when the car is making max power and has the most load on the engine components.
12-16-2015, 10:46 AM | #12 | |
Rep 6,771
Drives: 2016 BMW i8
12-16-2015, 11:24 AM | #14 |
Rep 1,749
Most load on engine is at peak torque, not redline. Peak fuel demand is at higher rpm and peak draw from coil and plugs. Therefore you probably realistically need to replace all coils as next step if no codes exist given you just changed plugs.
12-16-2015, 12:12 PM | #15 |
Captain Fatbelly
1423
Rep 1,994
Thanks. Think I'll pull the plugs over the weekend just to take a look....give me something to do while the wife's out of town. Anyone know a good source for coils? Ecs seems to be the cheapest but I'd love to find a whole set at a good price.
2008 dct coupe, evolve engine/dct tune, ttp, ms intake, megan exhaust, cf ds. Sold. Last edited by Doc Oc; 12-16-2015 at 12:58 PM.. |
12-16-2015, 12:38 PM | #16 |
Rep 1,017
Yea NGKs are OEM, been running them for about 18k myself.
12-16-2015, 02:06 PM | #17 |
Rep 56
Just went through this myself - ECs has a good deal on a complete kit, coils and plugs. Best I found.
12-16-2015, 04:08 PM | #18 |
Captain Fatbelly
1423
Rep 1,994
You are right, thanks, don't know how I missed it earlier. $700 bucks for the kit is good compared to everywhere else but I am still blown away that the coils are $85 each. Ridiculous compared to domestics and even Audi.
12-16-2015, 05:25 PM | #19 |
Rep 564
I had this happen to my e46 and it was the fuel pump. It couldn't keep up with demands under high loads. A clogged fuel filter could potentially cause this too and I think, for the e9x m3, the fuel filter in integrated in the pump. Something to consider as well.
2015 K46 S1KRR
2008 E90 M3 |
12-16-2015, 07:35 PM | #20 |
DSC Off!
307
Rep 718
I had the exact same problem and it was a coil. No CEL but Benvo was able to remote in and identify the specific coil so I didn't have to replace them all. Try tuner or stealer or you could always replace them all.
MCS 1WNR with 600/900 spring rates / Vorshlag camber plates / Apex ARC-8s with MSI studs / Stoptech Trophy ST-60/ST-40 / Cantrell Motorsports Brake Duct Kit / Cobalt Friction XR1, XR2s or PFC-11 pads / UUC Corsa axle-back with Fabspeed HFC and x-pipe / Schroth Quick Fit Pros / HANS Sport II / AA green filter / Coolshirt with large bag / Aim SoloDL with SmartyCam / CSF Radiator
12-16-2015, 10:16 PM | #22 | |
Rep 56
Hey Doc - just installed my new coil packs/plugs today and my hesitation issues disappeared. My car was stuttering and misfiring under high load, more so in higher gears. When I got in there I found the previous owner used Knockoff coils, definitely worth going OEM. Runs absolutely perfect now. No codes before the swap, I would definitely start there. Wouldn't worry about bore distortion, I doubt you'd experience hesitation due to bearings.
