12-22-2015, 07:31 PM | #1 |
Rep 2,495
KW Clubsport camber plates adjustability question.
I installed my clubsports the other day, and I have not got an alignment yet, but am hoping to run a -2.6 -2.7 up front, but it looks like there will be limited range of camber adjustment due to the hole being too small. Take a look below, the adjustment screws will not be able to be tightened if i went any further negative.
The Vorshlag plates i ran with my ohlins had a different type of adjustability. Let me know what you guys think. Is it safe to slot out the area to give the adjustment screw further adjustability? Passenger Driver |
12-22-2015, 07:39 PM | #3 |
Rep 2,495
12-22-2015, 08:57 PM | #4 |
Rep 368
I just slotted the inner lower ring, a race shop mentioned doing this before so I did so before installation.
12-23-2015, 12:59 AM | #5 |
Rep 5,329
just set the neg camber with the damper off the car now you have an idea where you need it to be, personally i wouldnt slot the strut towers as it just doesnt look neat and also come resale it looks very "modded" if you get me...
my way is little more time consuming but is the better way, now... if their was a way of making the actual opening larger very neatly id be all for that.
Z4MR VT2 - Clubsport build.
Multi award winning Detailing | Wrap | PPF specialists UK based - www.topwrapz.com |
12-23-2015, 09:43 PM | #6 | |
Rep 2,495
