KEEP M3POST ALIVE BY DOING YOUR TIRERACK SHOPPING FROM THIS BANNER LINK! |
02-24-2008, 06:51 AM | #1 |
Rep 291
Most aggressive ET for M3 E92 ?
What is the most aggressive ET with 8,5x19 and 9,5x19 or 10,0x19 for a M3 e92 without rubbing issues? Thank you for all the answers.
02-24-2008, 11:42 AM | #2 |
Rep 175
Usually there is a 1/2" to play with before rub problems. The stock ET is F/29, R/23. You could do an ET offset of approx F/15, R/10 and be ok assuming OEM tires/rim specs.
2022 M240i | Brooklyn Gray | Red Leather | Black 791M rim| Black trim | HK | Premium | M Lum
02-26-2008, 09:31 PM | #4 |
Rep 175
a 08 ET will be pushing it. That's 21mm the front wheel will be pushed out toward the fender, probably too aggressive. 19 ET should be no problem.
03-08-2008, 07:36 PM | #7 |
Rep 175
yes i'm sure. 29 - 8 = 21
03-12-2008, 02:02 PM | #10 |
Rep 150
Drives: Bee M Double U 335i 4dr
Because the car just arrived on the US shores and no one has any idea of the exact offset aftermarket wheels will be needed for fitment on this car, I'd be patient and wait to see exactly what will fit. You say you want the most aggressive fitment without rubbing which is fine, but you need to bear in mind the brand of tire that you will be using will probably come into play as well. Each and every single tire manufacturer have different size sidewalls even though the size specs are the same. This will affect how "aggressive" you can go as well.
03-18-2008, 11:28 AM | #12 |
//Mdicted
348
Rep 9,988
Drives: a Cop Magnet
Garage List 2009 e92 M3 DCT CF ... [10.00]
2015 S-Works Roubaix [0.00] 2013 Trek Madone 5.9 [9.50] 2012 Scott - CR1-Pro [10.00] 2008 e92 M3 6MT (Up ... [10.00] 2002 e46 M3 Cabriol ... [7.00] 2006 e90-325i (DD) [7.00] 2002 e39 M5 (retired) [9.50] |
WOW! nice wheels, very logical choice for me if/when I get the new Ms.
You did good!
03-27-2008, 06:18 PM | #16 |
Rep 3,071
Drives: E92M3-E46M3-E46Wagon-E89Z4-E36
He's right, spacers push the wheels out toward the fenders. You're going the wrong way if you're using spacers.
Invest Wisely...The best mod for your money?? BMWCCA high performance driver's school. The mod that lasts a lifetime and improves the performance of any car you drive[/LEFT]
03-28-2008, 01:49 PM | #17 |
Rep 125
03-28-2008, 09:13 PM | #18 | |
Rep 62
2010 BMW 335D
2006 YAMAHA R6 2004 Acura TL Aspec (Sold) 2003 BMW E46M3 (Sold) |
03-30-2008, 10:47 AM | #19 |
Rep 3,071
ET is offset. Tirerack.com has a good explaination on this.
03-30-2008, 11:10 AM | #20 |
Commander-In-Chief
2196
Rep 8,944
Drives: 2023 M2 Coupe, 2020 GLE 450
ET
Abbreviation for the German "Einpresstiefe", I believe.
Greg Lake Oswego, Oregon, USA 2023 M2 Coupe - Brooklyn Grey/Cognac/CF, 6MT; 2020 MB GLE 450 |
03-30-2008, 11:19 AM | #21 |
Rep 3,071
Here's the article. http://www.tirerack.com/wheels/tech/...urrentpage=106
