01-05-2016, 05:36 PM | #1 |
Rep 637
Drives: Nissan GTR / F06 M6
Radar Detector Hardwire question
Does anyone know which wire is a good one to tap into for hardwiring a radar detector in the interior light box above the rearview mirror? I have an F13 with carbon fiber roof.
01-06-2016, 12:56 AM | #3 |
M Master
74
Rep 551
Yea, dont do the overhead light, instead tap into the wire thats on the mirror stalk.. its also a green colored wire.. you can see some other install mentions of this wire color.. then just tap into any screw for the ground.. took me a few min. installing this way will keep the radar detector on at all times when the car is running.. from what ive read, tapping into the over head light wire turns its off when the car is in eco auto stop/start mode at a light.. I did however remove the top light area to stuff all the radar detector wiring guts and used a screw in there for the ground.. also when removing the over head console, make sure u pop out the middle of it first which gives access to push clips inside of it which then allows the whole unit to pop down.. it does require a bit of wiggling and force..
M History: E46 M3, E92 M3, E63 M6, F13 M6 Comp Pkg, E71 X6M
01-06-2016, 05:17 AM | #4 | |
Rep 637
01-06-2016, 04:31 PM | #5 |
Rep 291
I'm not sure if your using a V1, but I've had a very good experience with this Savvy:
https://store.valentine1.com/store/closeup_20220.asp It is super easy to wire, and you can have it auto-mute to a certain speed (if you live in the city for example). I have it in both of the cars at this point.
2020 X3M Competition
991 911 Carrera GTS Previous BMW: 2016 X5 M-sport 50, 2013 M6 AW/Black, 2012 X5M AW/Black, 2011 M3, 2008 335i, 2006 M3, 2008 335i, 2002 M3, 2002 330ci, 1997 M3 |
01-07-2016, 05:39 AM | #6 |
Rep 637
I was able to get it working last night. The 12v wire used was the green and brown wire in the harness going down the mirror stalk. The black and brown wire was used for ground from the overhead lighting secondary connector harness. Thanks everyone! I knew I could count on quick answers from M post.
