01-08-2016, 11:17 AM | #1 |
Rep 330
Benefits of solid subframe bushings on a stock car
I am curious if there's any perceivable benefits of solid subframe bushings on a car with stock suspension and engine.
01-09-2016, 04:18 PM | #3 |
Rep 1,266
Drives: 2016 M4 GTS
None...don't do it! If you car is a daily driver stay away from solid bushings as they are made for "race" cars.
2021 X5M Comp Marina Bay Blue
2016 M4 GTS Alpine White 2005 M3 Comp Interlagos Blue Instagram: @JustAnothaM4 |
01-09-2016, 06:39 PM | #4 |
Supreme Allied Commander
3893
Rep 54,605
Drives: F80 M3
You will have a rear axle that is very solid(responsive) and experience less on and off throttle rear torque steer. However, you will get more NVH into the cabin. On a completely stock suspension, don't even bother with the solid bushings. It's 6-7 hours of labor to get them done. You can invest that into some sport springs and upgraded struts and shocks and get more performance return on your money.
01-10-2016, 01:17 AM | #5 |
Rep 330
I like stock edc so am currently not interested in aftermarket suspension bits. I read a few mrf solid subframe bushing review and it seems there's 0 increase in nvh. I am surprised to hear opposite views on the nvh side.
01-10-2016, 10:29 AM | #6 | |
Rep 1,682
01-10-2016, 10:36 AM | #7 |
Rep 891
Absolutely ZERO nvh from subframe bushings. Most of the noise people are experiencing come from drivetrain (engine, tranny, differential) bushing mods. If these subframe bushings caused that much noise believe me they wouldn't be such a popular mod.
AWDBooSTIn90148.50 |
01-10-2016, 11:52 AM | #8 |
Rep 8,077
Drives: 11 E90 M3 Individual
I put solid subframe bushings into my e46 and you really don't get any NVH. I haven't ever experienced a significant increase in NVH with suspension busings (subframe, FCABs, RTABs).
When you go with poly or solid drivetrain bushings...you will get a lot more NVH.
2018 F30 320iX Melbourne Red
2011 E90 M3 Monte Carlo Blue 2004 E46 M3 Imola Red 2000 E36/7 Z3 Steel Blue |
01-10-2016, 03:18 PM | #9 | ||
Rep 12,738
Instagram; @roastbeefmike
01-10-2016, 07:04 PM | #10 | |
Rep 330
01-10-2016, 07:57 PM | #11 |
Rep 1,083
Solid Subframe Bushings WILL NOT add NVH
Solid Differential Bushings WILL add NVH Benefits - You will get less wheelspin from the get go - You can feel what the rear is doing - You get a better feel of the mechanical grip versus tire grip, increases confidence in car After all the upgrades I've done to my car, Solid Subframe Bushings is the best thing you can do to an E9x M3 to make it feel more alive.
BlueKitana92463.00 |
01-11-2016, 01:08 AM | #12 | |
Rep 330
01-11-2016, 06:59 AM | #13 | ||
Rep 8,077
The improvement will be subtle and likely undetectable. The reason why you do the subframe bushings preventively is to check them you have to pull off the entire rear end. At point...might as well change them. Also, why not install a longer lasting part which costs a lot of money/time to replace?
01-11-2016, 08:33 AM | #14 | ||
Rep 1,083
If you drive like most of the M3 drivers I've met (shift at least 6000rpm), then yep.
01-11-2016, 01:00 PM | #15 |
BimmerPost Supporting Vendor
732
Rep 3,735
Unfortunately lots of misinformation in here. There is NO NVH increase from changing the stock rubber sub-frame bushings to solid Sub-frame bushings. There is a great benefit on stock cars as well, you do not need to have a track prepped or race car M3 to take advantage of these. They will virtually eliminate wheel hop, they stabilize the rear end under cornering and acceleration and stiffen chassis rigidity which always is a good thing, even on a street car, as it will be less prone to being upset driving around.
BMW PERFORMANCE SPECIALISTS. Race Engines. Suspension. F/I. Brakes. Race Preparation. Factory Service. Alignments.
OFFICIAL PARTNERS: KW. MOTON. Brembo. AP Racing. BBS Motorsport. iND. HRE. Turner Motorsport. VAC. BMW Motorsport. Facebook | Instagram | Yelp! | Flikr Phone: 949-233-0448 | E-Mail: info@mrfengineering.com |
01-12-2016, 12:23 AM | #16 | |
Rep 12,738
01-12-2016, 01:41 AM | #17 |
3893
Rep 54,605
Drives: F80 M3
Perhaps their tolerance for NVH is much higher, there is definitely more NVH with solid subframe bushings.
01-12-2016, 02:11 AM | #18 | |
So Kewl Guy
49
Rep 619
Very accurate. I had solid subframe and turner delrin diff mounts and the only change was I could hear the diff whine at highway speeds (not that loud but definitely there). There was no increase in NVH (except diff whine) and I am EXTREMELY sensitive to NVH. I took apart my center console to pad the inside from NVH and that was stock bushings with catless pipes. Benefits listed above are spot on.
2010 E93 M3 / MS Catless X-Pipe / AA Catback / Vorsteiner Vented Hood and Bootlid E93 Trunk / ADV1 7.1 Wheels GB / LS3 LED Lights / Harrop Supercharger
01-12-2016, 12:21 PM | #19 |
732
Rep 3,735
No, there just simply isn't a detectable increase in NVH with solid subframe bushings. Having done nearly 100 of them in house now, none have ever said there is an increase in noise from the sub-frame bushings. The differential bushings, depending on type of material, will increase noise. There is no vibration or harshness increase from differential mounts, just gear whine.
01-12-2016, 12:24 PM | #20 |
732
Rep 3,735
It's a differential damper essentially. It will reduce the noise of the stiffer differential mounts by absorbing the noise.
01-12-2016, 01:40 PM | #21 | |
Rep 368
They weren't when I purchased the subframe bushings and diff mounts from you.. Feel free to PM me any information |
01-13-2016, 07:03 AM | #22 |
Rep 1,179
Malek - I'm thinking of pairing solid aluminium subframe bushes with Black series diff bushes.
In your opinion, would 95 shore A material as used in Powerflex Black series diff kit allow move NVH than the stock bushes? Cheers. |
