XBimmers X1   XBimmers X1
  XBimmers X1
Go Back   XBimmers | BMW X1 Forum > BMW X1 Forums > General BMW X1 (E84) Forum
Register FAQ Calendar Today's Posts
      01-15-2016, 09:58 AM   #1
walendvay
Drives: '11 F25 28i; '13 E84 35i
vanity visor light - retrofit? (without ambient light pkg)
Just picked up a fully loaded (minus ambient lighting) X1, 35i.
Has anyone ever attempted to install an OEM visor vanity light? The misses really likes having one. The visors in my car don't seem to be wired, so I thought to plumb the wiring to the map light (i.e. having it switch on/off with the right map light). I was thinking about doing this on the passenger side only.
thoughts? Anyone pull this off? Any other ideas?
      01-15-2016, 11:30 AM   #2
vstolpner
Drives: 2019 F39 X2 m35i
I've actually got the same issue with mine, wouldn't mind to know more about it as well.
      01-15-2016, 06:59 PM   #3
spydrz
spydrz's Avatar
Drives: '15 M4, '15 i3
06 330i  [7.00]
2002 X5 3.0i  [0.00]
2001 525i  [0.00]
Probably need the headliner with the molding for the lamps. It's an odd oversight for what is a relatively expensive vehicle in 35i trim especially.
2002 X5 3.0i/man.*
2006 330i/man./Arktis/Grau*
2001 525i/step./Schiefergrün/Sandbeige*
2013 X1 xDrive35i Alpinweiß/Schwarz/M Sport/Dinan Stage 2
*retired
      01-15-2016, 10:42 PM   #4
walendvay
I suspect I can cut a hole in the headliner. I am hopeful there are openings in the vehicle frame behind it. if I know there is constant power at the dome light,I might consider swapping the visors for the visors with switches. curious if anyone pulled off this type of retrofit.
      01-16-2016, 12:37 AM   #5
vstolpner
There is probably some constant power, but the switches are just buttons and the lights are computer controlled (if left on, they go off when you lock the car and don't come on after). So you might have to feed in to the entire dome console.
xbimmers
