02-09-2016, 02:10 AM | #1 |
Rep 152
Valve controller
Hi guys
Been reading about the can flap modules from burger motorsports obd II and also Macht schnell Has anyone in oz got one and did you get it locally or from overseas. Are you happy with it. Cheers |
02-09-2016, 05:04 AM | #3 |
Rep 152
02-09-2016, 07:15 PM | #5 |
Sunburnt Member
158
Rep 525
I have the Macht Schell unit and it works flawlessly. Couldn't be happier.... Aside from the ridiculous price that is.
Bought it from EAS when it first came out in a bid to appease the neighbours, but forcing the valves shut did little to mute the deafening cold start noise. Still... a very handy unit.
2019 Deep Blue Tesla Model 3 Performance | 2015 Mineral White F82 M4 | 2010 Burnt Orange Lotus Exige S2
Past: 2009 Ibis White S5 (APR Supercharged V8) Past: 2004 Imola Red M3 Convertible |
02-09-2016, 10:37 PM | #7 | |
Rep 152
Looking at the burger sports obd can flap myself |
02-10-2016, 03:08 AM | #8 |
Rep 5,530
02-16-2016, 04:23 AM | #10 | |
Sunburnt Member
158
Rep 525
Discarding the supplied wire taps, cutting, splicing and soldering the wires yourself? 30 minute job. Either way, piss easy job...
02-16-2016, 05:20 AM | #11 |
Sunburnt Member
158
Rep 525
Stuart, is BMR doing bench-flash tunes for F8Xs?
02-17-2016, 07:33 PM | #13 |
Rep 189
I've had both Macht Schnell and JB4 and the Macht Schnell module is better in the way that you can program it to default the exhaust flap position to open, closed or auto every time you switch off the car.
Doesn't sound like much, but you know about it if you forget to shut the valves and cold start with the exhaust open first thing in the morning! |
02-18-2016, 01:26 AM | #14 |
Rep 152
02-18-2016, 09:19 PM | #15 |
Rep 1,328
Maybe it's because I only just got my M (X5M), but I can't imagine wanting that cold start sound to be stopped. For now i've just done the valve mod (unplug cables) to get the valves open permanently, but there is a little drone. So this Macht Schnell system sounds like it would be handy to close the valves on the go when i'm on the highway, but still have an option to open them, even when in efficiency mode.
2020 BMW X3M Competition ///M - ALPINE WHITE / SAKHIR ORANGE Past: 18' BMW M3CS | 18' BMW X5M | '17 BMW M3 Competition | '16 Mercedes GLC250 | '16 BMW X5M | '15 BMW X5 M50d | '14 Audi SQ5 |
02-28-2016, 06:31 PM | #16 |
Rep 80
02-28-2016, 07:26 PM | #17 |
Rep 1,142
Been reading about CG Precision. You can use Homelink buttons to open and close valves.
Current: 2018 M3 | individual Fire Orange
Gone: 2016 M4 | BSM |
03-01-2016, 06:27 PM | #18 | |
Rep 5,530
Flash tune is just a way to distinguish this particular type of tune, rather than a 'piggyback tune'. The piggybacks work by plugging into a few sensors in the engine bay and fooling the engine into running higher power. The flash tune is a remap on the ECU, it's much more comprehensive as we're able to access a lot more info and parameters. Yes we can code out cold start If the flash tune is discovered while making a warranty claim there could be issues. I always recommend flashing back to stock before making any warranty claim (we make a backup and keep your stock file prior to making any changes) |
03-03-2016, 10:46 PM | #19 |
Sunburnt Member
158
Rep 525
After you bench-molest the ECU, you can flash the car back to stock, and then back to modified mapping through the OBD port right?
How long does this take, and how much do you charge, each time we need to put her in for service? I would LOVE to get rid of cold start.
