02-18-2016, 11:52 AM | #1 |
///M
158
Rep 3,195
Camber plate suggestions for non-coilover setup
Hi - I am running swift springs and want to get camber plates (F) for the casual track days.
Do you guys recommend vorschlag? GC?
2011.5 AW/FR E92 M3 6MT
02-21-2016, 11:20 AM | #5 |
Rep 8,077
Drives: 11 E90 M3 Individual
Casual? I'd maybe go Dinan. If you want to screw with your tie rods (which is easy on the E9X)...get the Vorshlag.
I had the GC's and they required annual maintenance because it has a roller bearing. Otherwise you get a whole bunch of clunking. Maintenance is removing the plate, complete disassembly, clean, and relube. Not worth it when I know the Vorshlag plates in my E46 haven't needed anything over the past 7 years except for a spring perch (new struts). Let's not forget the bolt plate which failed the first time I torqued the tower nut.
2018 F30 320iX Melbourne Red
2011 E90 M3 Monte Carlo Blue 2004 E46 M3 Imola Red 2000 E36/7 Z3 Steel Blue |
02-21-2016, 08:18 PM | #6 |
Rep 152
do the Vorshlag plates raise the suspension at all or keep the same front ride height? Wouldnt mind extra camber for the few years it will take me to save for clubsports.
03-01-2016, 04:52 PM | #9 |
Rep 139
Is there increased NVH with the Vorshlag?
'09 E90 M3 DCT EDC, ESS VT2 625, ESS HFC, GTS DCT, D2R BBK, B16D, VORSHLAG CP, DELRIN SUB, TE37SL
'00 996.1 GT3 CS |
03-01-2016, 09:53 PM | #10 |
Rep 12,738
i have the ground control adjustables for my edc car. i'm happy with them. my car sees track days and the streets. haven't had issues yet. no negatives to report, no noticeable difference in ride height.
Instagram; @roastbeefmike
03-02-2016, 09:09 AM | #11 |
Rep 1,673
I just installed the Ground Control last week on stock edc shocks. No noise or ride height changes. Cleaned the factory lube off the bearings and used Mobil 1 grease right off the bat.
Electronics Junkie, Engine Builder.
03-03-2016, 01:30 PM | #12 |
Rep 139
Are these the street or race GC camber plates? I am really concerned about noise and maintenance.
'00 996.1 GT3 CS |
03-03-2016, 01:33 PM | #13 |
Rep 1,591
I am running the street camber plates from GC along with custom springs from them, no issues so far and install was super easy.
2012 E92 M3
Instagram Turbo__Joe |
03-03-2016, 06:28 PM | #14 |
Rep 139
Thanks Joe. I see those are made of poly. Nice. What are your chosen spring rates, and how's the handling improved for you? Do you track the beast?
'00 996.1 GT3 CS |
03-03-2016, 07:49 PM | #15 |
Rep 1,591
No track time yet but have an autoX event in a few weeks. I did the GC coil conversion kit with 450lb front and 600lb rear springs. Awesome guys over there, talked to them about my set up and goals and they helped steer me in the right direction. Car is barely lower than stock.
03-06-2016, 02:47 PM | #16 |
Rep 139
Is there a difference between camber plates from GC, TCK, Vorshlag that change the level of maintenance or potential squeaking? I see some using urethane, some spherical bearings? How often do we have to change the bearings if we track 8-10 times a year?
'00 996.1 GT3 CS |
