03-13-2016, 09:45 AM | #1 |
Rep 241
To Space or not to Space? That is the question ...
Have OEM 343's in 20' with MPSS tires. What spacer options look / perform best (size as I presume all manufacturers are very similar) on the M5? By bumping the tires out, I would think more rock pits will show up on the door panels since more tire area is exposed to sandblast the panels?
03-14-2016, 10:10 PM | #3 |
Rep 3,834
12mm all around is ideal for our cars. You don't want any less than 12mm as it won't clear the hub lip. If lowered, go 15mm all around for a flush look.
Can't go wrong with BMS or MS brands.
Daily: G12 750 MSPORT Weekend Car: E90 M3
03-14-2016, 10:48 PM | #5 | |
Rep 3,834
03-15-2016, 09:13 AM | #7 |
Rep 3,834
I live in Shawnee, KS (suburb of KC). You?
03-15-2016, 09:52 PM | #9 |
Rep 3,834
Awesome. Ladue is a nice area, lots of beautiful mansions.
03-17-2016, 09:59 AM | #11 | |
Sergeant
28
Rep 142
_______________ ///M '16 535i Xdrive Msport '13 M5 - Singapore Gray, Black Ext. Napa, Dinan FF Exhaust, much more to follow. '12 X5 M - Carbon blk, Cinnamon interior <retired> |
03-19-2016, 07:21 PM | #14 |
Rep 2,039
04-01-2016, 10:30 PM | #18 |
Rep 3,834
They're hub centric and BMW specific. No issues reported on the BMS spacers, so you're good.
04-02-2016, 09:22 PM | #19 |
Rep 469
04-11-2016, 08:57 AM | #22 |
Rep 3,834
If your car is not lowered, I can see that 12mm might appear to stick out. I don't think you can put less than 12mm in front, as it won't clear the hub lip. Anything less than 10mm won't be hub centric.
But unless you have a measuring tool, how can you tell the difference between 10mm and 12mm? That's a difference of 0.08 inch (less than 1/10th of an inch). Hell, I can't even tell 2 drill bits apart with a difference of 1/10" looking up close. Maybe I don't have as good of a vision compared to you experts? With a drop, 12mm all around looks best.
