03-13-2016, 11:53 AM | #1 |
Rep 26
Essex AP Racing Pro 5000R BBK Initial Review
Hello, long time lurker here finally decided to make an account.
I have a 2011 LMB M3 with ESS VT2-625 supercharger kit. I just started tracking my car last year and while the stock brakes and decent pads were fine with the stock power. When I went with the supercharger, I burned them out in under a lap. I track my car mostly at the Mission Motor Raceway in BC, Canada which is known to destroy brakes. The last time I was there I got on it too hard and had almost no braking at the end of turn one and had to go off into the runoff. That ruined my day and I knew I had to step up the brakes. When I got back into the paddock, my rotors were over 600 degrees! I decided on the Essex AP Racing CP9660 front brake kit. After a ton of research, there's really nothing better out there right now. Best of all, the kit DOES fit under the stock 219M wheels with a 15mm spacer in the front (I'm running Apex EC-7 wheels on the track so no spacer needed there). I did the installation myself, which was a breeze but the bleeding was a PITA. I went through 1.5L of Castrol SRF with Motive Power Bleeder and I couldn't get the pedal 100% firm. I had to take it to my mechanic where he used the DIS electronic bleed which fixed the problem. The pedal feels great now! First track day is still about a month away, so I'll report back on how that goes. I'm running DS2500 pads front and back (rear is still OEM setup) and will switch the fronts to DS1.11 for the track. I'm only running 275 square NT05 tires so it should be more than enough. My only complaint about this kit is the pad rattle. The CP5060 kit has the option for the anti-rattle clips, but nothing for the CP9660 yet. Every decent bump in the road and there's a clicking noise from the front pads knocking around. Hopefully AP racing releases a clip for this caliper in the future. Also, support at Essex is top notch. They are a great company to work with. |
03-13-2016, 07:43 PM | #4 |
Rep 12,738
kit looks great! i have the other essex option for our cars up front. i was running the same ferodo ds2500 pads up front with oem rear brakes/pads. i'm not sure if i would run the ds1.11's with the oem rear's. you might be fine, but even with the ds2500's and oem rears i felt the rear end wanting to step out a bit if i was a little angled in the braking zone. run the 2500's and see how you like them. they are fine for me on the street/track.
i recently got ds2500 rear pads for my oem rear calipers/rotors, but i haven't had any track days on them yet, so nothing to report there. i'm hoping this is going to be a good setup.
Instagram; @roastbeefmike
03-13-2016, 08:03 PM | #5 |
Rep 26
Yeah, I'm running DS2500 in both the front and the rear for the street. Going to try and get away with the DS1.11 in the front and DS2500 in the back for the track.
Was going to get the rear kit, but the OCD in me can't handle their current non-matching caliper. I'll just wait until they release the Pro5000R rear. Also willing to try DS1.11 in the back as well, just not a huge fan of changing the pads in the back with the OEM calipers. Had to switch to studs as well. Went for MH studs which are 100% needed with spacers as rotors on this kit don't have a set screw. Its a mega pain trying to line everything up with the rotors moving around so much. |
03-13-2016, 10:09 PM | #7 |
Rep 1,083
Mission is ultra hard on brakes, and not that fun in my books.
I have the Street Radi-CAL Front 6/Rear 4 on my Harrop supercharged car. I wonder if only having Fronts affect the braking balance. What's the size of the front disks? Cheers, Sunny
03-13-2016, 11:48 PM | #8 |
Rep 26
Mission is fun when your brakes work, and is absolutely no fun if you are fighting that.
The rotors are 372x34mm and more than adequate. The calipers are much different than the Stillen Radi-cal ones though. All race part: SS vented pistons, no dust boots, no external lines. The kit is made to match the torque as close as OEM as possible so it won't throw off the balance to the rear. But I'll give an update once I get out there (if this rain ever stops) Hopefully all works as we have pretty limited track options here without heading south of the border. |
03-14-2016, 12:00 AM | #9 |
Rep 1,083
My car just sees the street so I think having the dust boot in a humid place is better.
03-14-2016, 11:05 AM | #10 | ||
Rep 842
Thanks for the initial feedback BlueMonster! I'm excited to hear your impressions after unleashing that SC'd beast on the track with our kit. I have no doubt you are going to be impressed with what you see/feel. Also thanks for the info on the wheel fitment. I'll have to get that up on our website.
03-14-2016, 09:24 PM | #11 |
Rep 26
Thanks Jeff!
Quick questions 1. Any reason why you guys omitted the set screws on the rotor hats? Doesn't make a huge difference for car with factory studs, but its a mega pain in the butt for BMWs. Would be nice if you put those back in. 2. Any idea if/when AP would make a anti rattle clips for the CP9660? Most people on this board DD their cars and the rattling isn't something you really want. The Ferodo pads seem to make this worst as I've heard they tend to fit small. |
03-15-2016, 10:09 AM | #12 | |
Dr. Octagon
261
Rep 1,919
I'm having the same problem with the Essex-suggested Ferodo pads on my CP5060/5040 Competition Kit. While they did send out anti-rattle spring clips for the front calipers that quelled the noise up front, the rears still rattle badly. Essex's response was simply that they have no solution available for the rears. I find it interesting that Essex advertises a focus on customer service and are requesting feedback from us, but don't seem interested in solving this issue... ...I'd hate for others to unknowingly order this product without this noisy side-effect being disclosed before purchase. Good luck and keep us posted!
OC ///M
2013 E92 M3 Individual Sold: 2011 E92 M3 SSII | Sold: 2008 E92 M3 SSII | Into a Wall: 2008 E92 M3 SSII | Sold: 2007 E92 335i JB |
03-15-2016, 09:33 PM | #13 |
Rep 26
I'm with you on that. I wish there was a little more transparency about the NVH issues with this kit.
The e9x M3 is still a pretty expensive car for most people to be entirely a track only car and most of us daily drive our toys. Seems like engineering a $5 piece of spring steel to keep some pads from rattling around shouldn't be that hard of problem to solve. Either way I still think its the best bet out there now as far as performance is concerned, so some sacrifices have to be made. |
03-16-2016, 12:00 AM | #14 |
Dr. Octagon
261
Rep 1,919
^ I'm in 100% agreement on all points.
OC ///M
03-16-2016, 12:19 PM | #15 | ||
Rep 842
Bluemonster, please see page 12 of the other thread in which NVH is being discussed.
As noted in this thread, also keep in mind that all pads from all manufacturers are different sizes, varying by a couple mm in some cases. It is impossible for AP Racing to produce a caliper in which all pads from all sources will fit like a glove and not move around at all. As I said in the other thread, if enough people are bothered by the issue, we can further investigate some options. It's not as simple as a $5 part however. When you make a $5 part you have to order 10,000 of them, which turns into $50,000 to chase a topic that we almost never get complaints about. We do appreciate the feedback and will continue to try and improve though. There is no perfect solution for all scenarios, but I think we are as close as anyone has gotten yet in the grand scheme of aftermarket BBK's. Thanks gents. |
03-16-2016, 01:28 PM | #16 | ||
Dr. Octagon
261
Rep 1,919
Up until that point all we knew was: Quote:
OC ///M
03-17-2016, 07:41 AM | #17 | |
Rep 842
03-17-2016, 06:33 PM | #18 |
Dr. Octagon
261
Rep 1,919
^ Hahaha...one of the all-time great movies!
OC ///M
03-17-2016, 08:58 PM | #19 |
Rep 2,495
Can you post a review of the supercharger on the track? I'm looking into a 625 kit, but don't want the reliability of the car to suffer at all.
2010 E92 M3 DCT
03-18-2016, 03:00 PM | #20 | |
Rep 26
On the track, I'll have to give you a update in a week. As I mentioned in the first post, my brakes gave up on me and I couldn't really push the car. The passing power is insane, especially if your shifting is good and you can keep the revs over 5k. I'll let you know how the system holds up once I can hit the track with the new BBK. I'll be at the track next weekend (3/26) |
