03-25-2016, 05:11 PM | #1 |
Rep 4,532
After 600 miles with Racechip on the X5M.....
Time to check the integration at part throttle and codes, potential codes , etc.
Ltrims under 5% shows why the module is factory smooth at part throttle and transitions. |
03-25-2016, 05:39 PM | #3 |
Rep 455
Thanks. Do you mind explaining a bit about what you were looking for here? I just looked up fuel trims and dashcommand, but since I'm new to this I don't know what you're showing here exactly. Any insight appreciated. Good to hear the mod is working great!
-------------------- Edit: also, what OBD-II monitoring hardware are you using? This is real-time monitoring? Thx again
2016 X5 M - Sapphire Black/Aragon Brown, IND Black front/side grilles/side markers 2014 C63, Klassen M52Rs, Eurocharged tune - Gone Last edited by jcfay; 03-25-2016 at 05:47 PM.. |
03-25-2016, 05:49 PM | #5 | |
Rep 4,532
RC is doing a good job. |
03-25-2016, 05:50 PM | #6 |
Rep 4,532
03-26-2016, 12:13 AM | #7 | |
Rep 13
03-26-2016, 09:27 AM | #8 |
Rep 4,532
I bought the Baravian cable (waste of money).
Then I bought the GoPoint BT1 and added DashCommand. That works ok to real time monitor and also real time log OBD2 parameters. This works well to monitor changes for a modest add on tuner box like the RC. It also verifies that the shift point safe guards are still intack, etc. which makes the RC a nice box. I am spoiled with the other software that I use to manually tune different platforms. The resolution is soooo much greater and is necessary when you start manually changing parameters and need finite response feedback. On the BMW DME, the two MAF sensors are draw through and give a first tier estimate of airflow, then the DME compares that to a VE table and VE calculation and fires the fuel injectors by pulse width, then the wideband O2 sensors measure the actual AF ratio and fine tunes the injector pulse width based on short term fuel trims (strims) , which set long term fuel trims (Ltrims) over a number of firing cycles. When you log the Ltrims under 5% it shows RC did their homework to integrate the module very well. The Ltrims are low and linear which is why you do not feel and part throttle stumbles, etc. Smooth as stock, just more HP. |
03-31-2016, 11:48 PM | #11 |
Rep 944
04-01-2016, 07:43 AM | #12 |
Rep 4,532
S1 should always remain at 1
S2 comes from the factory at B Leave it in B and test drive. If you can log data, log boost vs rpm. If you can not log data I would leave it on B. Each click up to c,d, etc will increase boost 0.50 - 0.75 psi roughly. |
04-01-2016, 08:43 AM | #13 | |
Rep 5,066
I have a 35i with MPPK with Racechip setting on S2:C for 6 months so far and I am thinking about moving to D.
2015 F15 X5 35i Msport Space Grey M Performance parts MPPK, MPE
04-01-2016, 09:00 AM | #14 |
Rep 4,532
Yes. D is factory smooth. If it wasn't RC would be removed. It's all a balancing act though when you exceed B. At some point increasing boost over a modest amount (2.5 -3.0psi) is going to cause issues. You could cause a rough stumble as it transitions into boost, you could exceed octane limits and the DME will pull timing and power even though it could still be smooth, you could exceed the MAF hertz limit and set a code, you could exceed the map limit and set a code. None of the above will cause damage if you are smart and pull it back when it happens. But you must log data to see what is happening if you exceed 3.0ish boost over stock to insure everything is working well. My M took D to get 2.5-3.0 increased boost. Another M might get there at B.
