03-30-2016, 03:28 PM | #1 |
Rep 424
IIHS Tests BMW LED Headlights; Low Scores
"The Prius v's LED low beams should give a driver traveling straight at 70 mph enough time to identify an obstacle on the right side of the road, where the light is best, and brake to a stop," said IIHS senior research engineer Matthew Brumbelow. "In contrast, someone with the halogen lights would need to drive 20 mph slower in order to avoid a crash."
At the other end of the spectrum, the halogen lights on the BMW 3-Series were deemed the worst among 44 headlight systems to earn a 'poor' rating. A driver would have to be traveling no faster than 35 mph to stop for an obstacle in the travel lane. BMW's upgraded LED curve-adaptive lighting is better, but not good enough to earn above a 'marginal' score. Read more: http://www.leftlanenews.com/iihs-tes...#ixzz44Q6ebr1f |
03-30-2016, 05:36 PM | #3 |
Rep 88
Was expecting better
Watched some videos. Probably why not seeing much improvement for me. The roads I drive a mainly are heavily traveled. The sensors are trying to direct light away from other cars. so doubt getting anything close to what the LED's designed for Last edited by 2016sx5; 04-03-2016 at 12:43 PM.. |
03-30-2016, 06:23 PM | #4 |
Self-Deprecating Narcissist
7274
Rep 6,561
perhaps they should focus on the antiquated dot laws that prohibit better lighting to be available in the US/NAR. I have always installed E-Code / Euro Spec headlights on nearly every vehicle I owned. The cut-off is sharper, the headlights vary between 20-25% more light than their US/NAR counterpart, they illuminate more of the shoulder and traffic signs and of course they are aesthetically pleasing since they do not have a large gross amber reflector. Below you can see some of the differences between the US/NAR Tri-Xenon AFS Adaptive Headlights found on the 2015 Q7 versus the European version for the same vehicle:
OEM E-Code Headlights & Philips XV50 Bulbs: OEM Philips vs. Philips XV50: North American Region OEM Projector Cut-Off: European OEM Projector Cut-Off: European OEM Headlight Illuminated: Beam Pattern At Night In Winter: High Beam Pattern At Night In Winter: Autobahn / Highway Mode Enabled: http://www.audiworld.com/forums/q7-d...alled-2867109/
Chadmatic660.50 |
01-03-2017, 08:47 PM | #5 |
7274
Rep 6,561
4L Q7 w/ E-Code headlights vs. F15 X5 LED Headlight with Euro Anti-Dazzle:
nyalpine907444.00 |
