04-03-2016, 10:14 PM | #1 |
Rep 46
2012 135i n55 ready to mod
Hey guys,
The pass couple of days I been reading these forums quiet a bit in order to research modifying my 2012 135i w/ DCT a bit further. So far I have the JB4 stage 3, Intake and just order a catless downpipe today. From my understanding once I get the downpipe installed I could be running the JB4 on MAP 2? Can anyone confirm this? Also my next mod is an upgraded front mount intercooler and oil cooler. I would like to reach 400whp on my car, but not sure these mods will be enough for the n55 engine as I read some posts that the N54 makes more power with the stock turbos and can reach 400whp pretty easy. Can someone provide me with some guidance on how to successfully achive 400whp on a 2012 135i n55 motor? Thanks in advanced. |
04-03-2016, 10:36 PM | #2 |
Rep 1,850
You're not gonna get a legit 400 whp without a hybrid / upgraded turbo or fueling with 100% methanol (and all the fueling upgrades / headaches that would case). Reason being the turbos can't flow enough air. Methanol would work because although it has less energy per weight than gas you can cram WAY more in thus making a bigger bang per amount of air.
Anyway, what you DEFINITELY want is water / meth injection. HUGE bang for the buck. It will heavily supplement your intercooler, especially if you inject directly after it, suppress detonation--especially if you spray thru a throttle body spacer--and add a little fueling any way you go. You can easily inject in 2 or more locations using using simple connectors all the meth kit guys offer. Don't use brass fittings from the hardware store as they will be attacked by the methanol. Mix the water and methanol 50 / 50 by WEIGHT. You can also use denatured alcohol / ethanol but DO NOT use isopropyl!! It doesn't work. As far as safety goes, the JB4 leaves the engine's internal safety mechanisms intact and they're more than enough to deal with a standard meth / JB4 setup on stock turbos. |
04-03-2016, 10:42 PM | #3 | |
Rep 46
So if I get FBO's and upgrade the turbo should I hit the 400whp easily? |
04-03-2016, 10:55 PM | #4 | |
Rep 1,850
If you're willing to modify the turbo you could get 500+ whp but you'll also need fueling. I don't believe there are any real offerings in the way of enlarged turbine housing / turbines either, which means the part powering the compressor is gonna get really damn hot during any extended use of that power so your turbos may not last very long. |
04-03-2016, 10:58 PM | #5 |
Rep 46
Thanks for your feedback. When upgrading the turbo to an aftermarket turbo when it comes to fueling is upgrading injectors and fuel pump is sufficient?
04-04-2016, 03:38 AM | #6 | |
The Crowing
111
Rep 2,005
2009 135i : BMS JB4 G5 ISO,CXRacing FMIC Kit,Injen Cold Air Intake,Evolution Raceworks Charge Pipe,Walboro Inline Fuel Pump, E85 BMS Backend Flash w/ 60% E85,BMS Meth injection (trunkmount),BMS dual meth nozzles,Spec stage 2+ clutch w/ steel SWFW,BMS Catless Downpipes,Berk Tech Race Axleback |
04-04-2016, 03:57 AM | #7 |
Rep 1,850
04-04-2016, 11:01 AM | #8 | |
Rep 46
? Seems like 520 is a bargain. Thank you. |
04-04-2016, 11:23 AM | #9 | |
The Crowing
111
Rep 2,005
04-04-2016, 12:28 PM | #10 |
Rep 46
Thanks for the feedback I will most definitely do that. I was sort of looking for recommendations. Thank you!
04-04-2016, 04:38 PM | #11 |
The Crowing
111
Rep 2,005
I'm a cheap ass so I would go with the cheapest you can find. with where your going, pretty much either one is going to do the job with almost little difference.
04-05-2016, 08:52 PM | #12 | |
Rep 917
If you go with something like Pure Turbos' Stage 2 turbo upgrade then you'll want to upgrade the high pressure fuel system also in order to max out the turbo's potential. There are 2 options there. You don't replace the injectors but add more fuel in 1 of 2 ways...Port Injection or Throttle body injection. Currently port injection seems to be the best option based on users experience but it's crazy expensive. Based on what I'd read so far... up to... 350whp - no fuel upgrades necessary 350whp - 450whp - Stage 2 LPFP 450whp - 550whp - Stage 2 LPFP + Throttle body injection OR Port injection 550whp + - Stage 3 LPFP + Port injection People seem to really like the stepped intercoolers. Wagner gets pretty good reviews.
2011 135i M Sport 6MT LeMans Blue | Active Autowerke Gen II axle back | Berk d******* | N54 gutted mids | FuelIt Walbro 450 fuel pump | Pure Turbos Stage 2 | 3.5bar TMAP | Pure Turbos inlet pipe | BMS intake | BMS oil catch can | ETS intercooler | ETS charge pipe | BMS JB4 w/ ISO firmware | BMS backend flash stacked on PPK | Eibach springs | Whiteline rear subframe bushing inserts | cosmetic tidbits
