04-06-2016, 07:57 AM | #1 |
Rep 20
E92 M3 Quote Check
I have a 2008 E92 M3 DCT with 50,000 miles and got a quote for following items to be replaced at a reputable BMW shop:
Spark plugs DCT fluid replacement Rear diff fluid Coolant Power steering fluid Brake fluid Total is about $850. Does this sounds fair? All BMW fluid and parts to be used. Also, any additional items I should be aware of to change at 50,000 miles? Thanks for the help. |
04-06-2016, 11:42 AM | #2 |
Rep 876
That seems very reasonable to me. My estimate is that just the parts are ballpark $540 (retail pricing). Spark plugs, DCT fluid, and rear diff fluid are expensive for our cars. You are probably being charged 3 hours labor total which is very fair considering the spark plugs labor alone is probably 2 hrs. It's going to increase your cost but I would also change the transmission filter at this time.
If you want to save some easy money, you could always get the spark plugs yourself on Amazon for $10 each which would save you $150 from the BMW branded part ($30 x 8). This NGK plug is the exact same as the factory spark plug as NGK is the OE supplier as well. Last edited by oolas3; 04-06-2016 at 11:48 AM.. |
