04-08-2016, 01:16 PM | #1 |
Autocrosser
10
Rep 50
Secondary Air Valve Replacement - How to access?
My car is throwing a fault code for a bad Secondary Air Injection (SAI) pump. It is my understanding that these go bad due to faulty Secondary Air Valves, which fail in the open condition and allow exhaust gases to flow backward into the pump. I would like to replace the valves when I replace the pump to prevent premature failure of the new pump.
I searched long and hard for a DIY or even just some photos, but it doesn't seem there's any information about accessing the Secondary Air Valves. I'm trying to figure out how they are accessed before I begin the replacement procedure. Are the valves accessed from above the engine, or from underneath? Any tips or tricks would be greatly appreciated. Here are some relevant photos: |
04-10-2016, 01:42 AM | #2 |
Rep 136
I did it a mix of from under and on top...the outer bolts closer to the firewall is what I did from up top.
For the lowers I lowered the Tranny and let it hand down, you should remove the fan before doing so as well. |
04-10-2016, 07:09 PM | #3 |
Autocrosser
10
Rep 50
Thanks for the info. I haven't been under the car yet, so I'm not familiar with how the transmission is mounted. How did you go about lowering it?
04-10-2016, 07:49 PM | #4 |
BimmerPost Supporting Vendor
3391
Rep 7,543
Might save you some time and $ to tune it out if you prefer that route.
-----| Like us on Facebook | Instagram || Tuning Information | Remote Coding |----- ----Visit us at www.BPMSport.com - Emotion. Driven. | Toll Free: (888) 557-5133---- |
04-10-2016, 08:44 PM | #5 |
Autocrosser
10
Rep 50
I have the ESS tune, and the cold-start is definitely disabled. I'm still getting DTC 27AF for the Secondary Air Pump. They are known to fail, so I'm assuming mine has. Are there tunes that suppress the SES light for a failed pump? I have to pass an OBD scan for inspection here in NY.
04-14-2016, 05:41 PM | #6 |
Rep 136
03-22-2017, 05:04 PM | #8 |
Rep 57
looking from under the engine I don't see an easy way to access the bank 1 valve either. Here is a picture
Mfanatik how did you lower the tranny? are there steps for that somewhere? |
03-20-2018, 01:26 PM | #10 |
///M Powered for Life
11511
Rep 10,342
You can usually pass with one sensor off, but then you'd need to have cats
03-20-2018, 01:47 PM | #11 |
Rep 87
Ah thanks. I think I'll most likely replace the valves. My pump works (I feel it pull air on startup) but the tubes may be blocked. Anyone have experience accessing the valves? Is dropping the tranny absolutely necessary?
03-21-2018, 08:09 AM | #12 |
3784
Rep 2,918
Drives: 2011 E93 M3
No you don't need to drop the transmission. You can do it from above. If you have smaller hands and patience, you only need to remove the cowl filters and if you still have difficulty, you may also need to remove the engine wiring harness (or unsecure it and move it forward enough to reach behind.)
DrFerry6734.50 |
03-21-2018, 11:40 AM | #13 | |
Rep 3,982
Dave
2020 Ford Mustang GT 6MT PP1 444rwhp
(Sold)2013 M3 Coupe-MR/BLK ZCP, 2011 M3 Coupe-MR/Blk 2007 Porsche 997C2S Speed Yellow/Blk sport seats 2004 BMW M3 Imola/Blk |
03-30-2018, 07:14 AM | #15 |
3784
Rep 2,918
Drives: 2011 E93 M3
Yes that’s why I posted.
01-21-2019, 11:18 PM | #17 |
Rep 25
The BMW way is to take out the entire exhaust manifold. Insane.
https://workshop-manuals.com/bmw/3_s..._valves_(s65)/ |
01-25-2019, 02:25 AM | #19 |
mTekMods
2169
Rep 2,922
Remove the cowl panel and use a racheting wrench on the top nut and low profile Rachet on the Lower nut, it’s not impossible to do.
2011 Frozen Black/Fox Red E90 M3 650+WHP
G-Power Supercharged First DCT to Manual Conversion Worldwide KW CS, BBS RI-A, BW Headers, Snow 2.5 |
DrFerry6734.50 |
01-25-2019, 02:25 AM | #20 |
mTekMods
2169
Rep 2,922
I can Do this for you in queens if you need help to remove them.
07-31-2019, 09:14 AM | #21 |
Rep 112
Just curious if anyone has any updates on this work or any more experience? I will be performing this work in the coming weeks to pass emissions in GA.
I get that we have to remove the cowl panel but no one mentioned having to remove the plenum? Can we do this without removing the plenum? Thanks in advance!
04-15-2020, 04:05 PM | #22 |
Rep 746
sorry for reviving and old thread, any luck from anyone? people did say you can do it from the top but the clearance is little to none.
