BMW X5 and X6 Forum 2014-Current
Go Back   BMW X5 and X6 Forum (F15/F16) > BMW X5 (F15) and BMW X6 (F16) Forum > BMW X5M (F85) and X6M (F86) Forum
      04-15-2016, 02:37 PM   #1
Manoloiv
Drives: 2016 X5M
Heavy vibration from car/steering wheel when letting off the throttle
Greetings,
My car has roughly 3000 miles and this morning it began to vibrate when letting off the throttle at low speeds. The vibration is felt through the steering wheel and in the seat. The closest thing I can describe it to is braking with warped rotors.fIt makes a similar sound and it is felt in the cabin. My wheels and tires are perfect. When initially pressing the brake pedal, there is an unfamiliar feeling and a slight vibration but not as pronounced as when simply letting off the throttle.
Please share your thoughts as I am concerned.
I read the post about the wheel bearings and I dont hear a clicking or clacking sound.
      04-15-2016, 02:48 PM   #2
m34SPD
Picture me rollin'
m34SPD's Avatar
Drives: e36 m3, e39 m5, f80 m3 CS
It's the rotors, the dealership will replace them and the pads.
      04-15-2016, 02:49 PM   #3
Manoloiv
Drives: 2016 X5M
Are you certain ?
Has this happened to your car ?
      04-16-2016, 04:48 PM   #4
m34SPD
Picture me rollin'
m34SPD's Avatar
Yup, the shop foreman drove it and said the rotors needed to be replaced.
      04-17-2016, 04:25 AM   #5
ajob
ajob's Avatar
Monaco
464
Drives: X5 M
Similar steering wheel wobbling happened to me years ago in a Grand Cherokee.
In my case the reason turned out to be my stupid insistence to often strongly pump the brake when stopped, to catch up with the longer pedal travel as brake pads got thinner.
This once brought one front pad to remain slightly but constantly pressed against the rotor: at sustained highway speed the rotor finally overheated, warped somewhat and the steering wheel started to wobble more and more, quite disconcerting.
Stopping the car, I was lucky to see a little smoke from the brake. I removed the wheel, levered the brake pad a little away from the rotor and drove off.
The rotor kept a little permanent warp, but I lived with it until the next brake & rotor change.
      04-17-2016, 07:17 AM   #6
jcfay
jcfay's Avatar
Drives: 2016 BMW X5 M
Warping can occur after heavy braking (hot rotors) and then keeping the pads pressed on the rotors. Has this happened? One reason not to apply parking brake after heavy braking and to let rotors cool if one decides to bed down the brakes.
2016 X5 M - Sapphire Black/Aragon Brown, IND Black front/side grilles/side markers
2014 C63, Klassen M52Rs, Eurocharged tune - Gone
      04-17-2016, 10:32 AM   #7
Manoloiv
Drives: 2016 X5M
The lug bolts were not torqued properly on the left and right rear wheel !
I discovered this after 2 days of pondering what it was.
Thanks for the feedback gentlemen .
      04-17-2016, 01:41 PM   #8
jcfay
jcfay's Avatar
Dude that is bad. The dealer did it? You may want your lugs, wheels and suspension checked.
      04-17-2016, 01:43 PM   #9
Manoloiv
Drives: 2016 X5M
I had each wheel removed, bolt threads inspected, hub threads inspected and hubs. Everything is ok.
xbimmers
