05-05-2016, 04:00 PM | #1 |
Rep 268
JRZ RS1 Nitrogen Pressure?
I just got a set of JRZ RS1's used from another member here, and I was wondering if anyone has adjusted the nitrogen pressure in their dampers.
I really don't have a clue as to what pressure range they should be in, especially on a primarily street car. I've read anywhere between 150 and 300 PSI, but that's a pretty broad range. I won't be installing them for at least 2 weeks(Have to get RSFB's in first) and I'd like to make sure everything is in good working order before I put them on. If anyone has any insight into what pressures are acceptable, please share. Thanks |
05-05-2016, 07:01 PM | #2 |
Rep 23
Due to cavitation in high pressure monotubes, 10bar is the minimum recommended. Above that allows for more leakage, and can be a tuning tool. If you are on the street, 150psi will ride much better. If you set them to 150psi, check them regularly, especially if you are tracking them. Cavitation can cause expensive damage quickly.
I have heard that they improved the new valving so you can run down to 8bar, but not sure I'd risk it without confirming what's inside during a rebuild. |
05-06-2016, 02:22 PM | #3 | |
Rep 268
05-07-2016, 11:59 PM | #4 | |
Rep 5,482
This may or may not translate to the JRZ's but MCS recommends 100psig or more for street use, and more if you need the extra "spring" rate or the dampers are being used hard, up to 300psig, though keep in mind this will affect ride height especially up front so be prepared to check toe if you're making significant changes for street vs. track. I usually ran about 105-110 in front and 150 rear on the street, and added some if on sticky tires, left alone if on street tires for motorsport activities
05-08-2016, 12:12 PM | #5 | |
Rep 268
05-10-2016, 09:48 AM | #8 |
Rep 1,266
Drives: 2016 M4 GTS
150psi in all 4 canisters for street and track. If you need "more spring" I believe 25psi is like adding 15 ft/lbs of spring.
2021 X5M Comp Marina Bay Blue
2016 M4 GTS Alpine White 2005 M3 Comp Interlagos Blue Instagram: @JustAnothaM4 |
06-01-2016, 08:20 AM | #10 |
Rep 3,251
Even 10 psi will "lift" the car by a tiny tiny amount.
Given the small diameter of the shock and the weight of these cars, the effects of such will be barely noticeable unless you are running hundreds of PSI in each shocks.
09 BMW E92 335i: Top Mount EFR 7670 / Dinan / AP Racing / Wavetrac / TC Kline [Full Mod List]
07 BMW R1200S: Shine Yellow / Akrapovic / Ohlins 19 Volvo V90 T6: R-Design / Bowers & Wilkins / Polestar Optimization |
06-02-2016, 08:14 PM | #11 |
Rep 268
I should be getting the dampers filled up tomorrow at a race shop nearby.
Ill try and let you guys know what I learn is recommended for different applications, and what pressures I go with. |
06-02-2016, 08:52 PM | #12 | |
Rep 2,495
I am winding up just ordering all my own stuff. You can have a good setup for around 300 bucks. I am planning to run 14 Bar in my Moton reservoirs. Interested to see what you like. What are your spring rates?
2010 E92 M3 DCT
06-03-2016, 11:18 AM | #13 |
Rep 268
450# front, 800# rear. I should be installing everything this weekend, so weel see how it works out...
06-03-2016, 06:07 PM | #14 |
Rep 268
Well, one front damper was at 150 psi, other was a 300. One rear was at 210, other was at 250.
I'm glad i got them checked. Set all 4 to just over 200 psi since that was kind of in the middle of where they all were already at. Guy I was talking to said 150-250 is where most are at, and 300 is pretty high. He said front to rear are usually run pretty similar, but that an extra 25 or 50 psi can be used to artificially raise the spring rate if you're in a tight spot. After seeing this, ill probably be buying the nitrogen damper fill kit from Bimmerworld in the near future. I think it's a good idea to check the pressures every so often, just to be safe. |
06-04-2016, 08:20 AM | #15 | |
Rep 2,495
2010 E92 M3 DCT
06-11-2016, 04:49 PM | #16 |
Rep 268
Finally got them put on this weekend. They feel stiffer than stock, but much less harsh. Haven't had time to play around with the adjustment too much, so weel see how it goes...
06-16-2016, 08:47 AM | #17 | |
Rep 1,266
Drives: 2016 M4 GTS
I would keep compression and rebound around 1 or 2 clicks and set the pressure to around 150-175psi in all canisters. It should feel very comfortable at those settings.
06-16-2016, 09:24 PM | #18 |
Rep 268
I'm still messing with the settings, trying to get a feel for what the front stiffness feels like is a little difficult. Each click of adjustment does have a noticeable change in damping force though, which is great.
06-16-2016, 10:01 PM | #19 | |
Rep 2,495
2010 E92 M3 DCT
06-16-2016, 10:49 PM | #20 |
Rep 268
No, same pressure for both. I've been within 8 clicks of full stiff and 6 of full soft, and there is an enormous difference. I think running within 2 clicks of full stiff for AutoX or track would be fine with the pressures I've got.
06-17-2016, 06:29 AM | #21 | |
Rep 2,495
2010 E92 M3 DCT
08-08-2016, 07:15 PM | #22 |
Rep 268
Went and got my dampers filled to 250 PSI the other day, I left the comp/rebound setting the same and I think I like this better.
My dampers settings are right in the middle of the adjustment range, and they are completely comfortable on the street. I also found this nifty little piece of information (below picture) Looks like I was right on the money as far as the recommended pressure goes. I might try 300 psi next time I'm by the shop. |
