05-05-2016, 10:47 PM | #1 |
Rep 147
Drives: E92 M3
White smoke on cold start
Hi I just bought bmw m3 e92 dct 2010 had 8.9k
2 day ago I bring to dealership to do general check up before I buy this. Found a cracked in the oil pan and a little leak in transmission pan so I straight away order both and I also attached the fault code. My mechanic said better change the speed sensor and abs sensor and alternator but is not urgent. So I postpone change that 3 item since it's quite expensive as well. Should I change that 3 item now or I just wait until it broken? This is my concern Yesterday night, When I refills oil about 1/2 liter and I start my engine and it had white smoke but not thick it's like fog/vapor. I drive around 1 mile to check oil level since the oil pan is leak and dealer not have ready stock I need to wait around 3 weeks. After that white smoke disappear, I turn off my engine and today I start my engine and it's fine there is no white smoke. Should I concern about the white smoke? My car had free flow exhaust system (delete catalic) I live in Indonesia which is always summer and have high humidity 86f and 70% humidity I read through this forum a lot common issue with m3 is rod bearing, any symptoms when u had rod bearing problem? Thx for your help Last edited by dry87; 05-05-2016 at 11:00 PM.. |
05-05-2016, 10:49 PM | #2 |
Rep 147
Drives: E92 M3
I attached result of general check up yesterday
05-06-2016, 12:47 PM | #3 |
Rep 656
probably just condensation in the exhaust... I would definitely get the oil pan fixed soon though... Looks like someone drove that thing off road...
05-06-2016, 02:35 PM | #5 |
Rep 24,946
Spot on !
"MAX VERSTAPPEN" IS THE 2021+2022+2023 F1 WORLD CHAMPION - #UnLeashTheLion
BPM DEV-Tune & DCT Software-Tune & Servotronic & coding ///Alpine HID Angeleyes ///Oem.exhaust mod. |
05-06-2016, 02:37 PM | #6 |
Rep 24,946
Bearing replacement is "not" required in this case because the car has only 8.9K on it.
White exhaust smoke is normal .
05-06-2016, 03:31 PM | #8 | |
Rep 24,946
OP's cracked oil pan is proof.
05-06-2016, 08:15 PM | #9 |
Rep 613
Drives: 2013 M3 coupe' 6mt
White smoke makes me wonder about gasoline quality.
memories: '71 2002 (new), '72 Bavaria, '74 2002tii, '00 540i Sport |
05-06-2016, 08:52 PM | #10 | |
Rep 147
Drives: E92 M3
05-06-2016, 08:54 PM | #11 |
Rep 147
Drives: E92 M3
When usually s65 need to change rod bearing? How the symptoms that I need to change rod bearing?
05-06-2016, 09:01 PM | #12 |
Rep 6,733
White smoke can be coolant. Check the other thread about white smoke
http://www.m3post.com/forums/showthread.php?t=1254213 |
05-07-2016, 06:59 AM | #13 | |
Rep 24,946
But also by abnormal ticking or rattle noises (rattle noises = game over)
05-07-2016, 07:02 AM | #14 | |
Rep 24,946
And he has cat delete ..
05-07-2016, 10:25 AM | #16 | |
Rep 147
Drives: E92 M3
05-07-2016, 10:29 AM | #17 | ||
Rep 147
Drives: E92 M3
05-07-2016, 10:29 AM | #18 |
Rep 24,946
With only 8900 miles or km on it , you don't need to think about BF .
05-07-2016, 10:31 AM | #19 | |
Rep 24,946
Just keep your cracked oil pan in mind ...
