03-15-2008, 02:50 AM | #1 |
The One And Only
15
Rep 398
Drives: 2006 TiAg ///M Roadster
IPASS problems
So earlier today I put an IPass in my 2003 2.5 Z4, and all of a sudden, like within minutes afterwards, all the keys i had just totally stopped working. I have heard online that the IPASS in a Z4 will sync with , and fully reset the central locking, is this true? And if so, what can i do to save my keys/central locking?
03-15-2008, 08:49 AM | #2 |
Rep 490
1. Does the central locking button still work?
2. Have you removed the ipass and reprogrammed the keys to the car, then tried to use it again with the ipass out of it? you can find the reprogramming info (or have a valet at the dealership do it) by searching some of the forums. I've forgotten most of it, so i'm useless here. Haven't seen you around lately, how's school. Also, you should hit the age thread, you might be the youngest with a Z4.
03-15-2008, 10:51 AM | #4 |
Rep 274
Drives: 2010 128i Conv.
03-15-2008, 06:46 PM | #5 | |
The One And Only
15
Rep 398
School is going good, I found a site with the whole procedure, ill try it out later tonight and tell u guys if it worked. For anybody curious its somthing u put into your car and instead of stopping when u pay tolls , u just put money on this thing and u drive right through, I have been to the age thread, I think I'm the youngest, whats been going on with you?
03-15-2008, 10:00 PM | #6 |
Back in a BMW
205
Rep 5,208
Im gonna guess its like SunPass (the thing you stick on your windshield, so you can drive through toll booths at 80mph.
Ian
03-15-2008, 10:16 PM | #7 |
The One And Only
15
Rep 398
Yeah no, this procedure thing didnt work at all, one key worked like 1% of the time, and the other doesnt seem to respond to anything at all, this is the procedure i used:
Get in Car Lock doors turn ignition on then off within 5 seconds hold unlock, while holding unlock press the lock button 3times in ten seconds release lock doors should unlock Yeah nothing seems to be working, i assume the dealer cost to fix this will be high, unless somebody has/finds a procedure that works
03-15-2008, 11:16 PM | #8 | |
GRDz4roadster
Rep 4
03-16-2008, 03:37 AM | #9 |
The One And Only
15
Rep 398
Just curious where on the windshield is yours on? Mine was right under the mirror piece
03-16-2008, 08:32 AM | #10 | |
Rep 274
03-17-2008, 12:37 PM | #11 |
GRDz4roadster
Rep 4
03-17-2008, 03:47 PM | #12 |
My favorite sign.
169
Rep 4,333
It seems like the Frequency the key fob works off of on the Zs are extremely prone to interference. I'm guessing the iPass is on a similar freq and throws everything haywire in the system. I dunno what a good work around would be, unless the mirrors on other models use different frequencies.
03-17-2008, 05:16 PM | #13 |
Rep 1,379
Drives: E89 Z4 sDrive28i M Performance
no problem with my iPass. I keep in in the lock box between the seats when I am not using it, then mount it with suction cups behind the mirror when I am using it. No issues.
03-18-2008, 09:58 PM | #16 |
Rep 1,379
03-19-2008, 07:39 PM | #17 |
Rep 152
If you truly are having issues with the IPass, you may want to go buy one of the ones that mount on the license plate instead. From http://www.illinoistollway.com:
Can I use I-PASS if I have GPS or a special windshield? A very small percentage, less than 1 percent, of vehicles have windshields or systems that interfere with transactions using the windshield-mounted transponder. In this case, a License Plate Tag (LPT) which mounts on the front bumper of your vehicle is available for the same price as a standard transponder. Buy online, call 800.UC.IPASS or refer to the Customer Service chart for more information about obtaining an LPT. Learn more about special windshields. |
