05-25-2016, 07:14 PM | #1 |
Rep 3,071
high oil consumption 700 miles
I am now getting only 700 miles before having to add oil. Dealer has comped last two bottles. Service Guy says drive harder.
Suggestions? No leaks that I see and they said they will test when I go in for next maintenance, but that is not considered too much oil. Currently at 36k miles.
Previous BMW: 16 M4, 13 M6; 14 M235i, 12 BMW M3; 11 BMW M3; 08 BMW M3; 08 BMW Z4M; 04 X3; 02 M3 Convertible; 02 M3; 00 M Roadster; 94 325 convertible; 92 325i Convertible; and 85 635csi
My Car Photo Blog: http://carfisheye.blogspot.com/ |
05-27-2016, 11:23 AM | #2 | |
Rep 6,075
I'm almost at the same page you are
Current : 2020 F92 Black Sapphire M8 - ZF8
Gone : 2018 F80 Mineral Gray M3 - 6MT Gone : 2016 F82 Austin Yellow M4 - 6MT Gone : 2013 F13 Sakhir Orange M6 -7DCT Gone: 2013 F13 Alpine White 650i -ZF8 |
05-27-2016, 11:41 AM | #3 |
Rep 676
Drives: 2015 M6 Gran Coupe
I haven't had to add oil more than once in my 12k miles so far. Driving at high RPM at all times must help.
my F10 550i however was so oil thirsty, I had to add a quart of oil every few months.. although that oil was much cheaper than M oil |
05-27-2016, 05:25 PM | #4 |
Rep 3,071
Luckily the M6 oil is not the M3 oil....$7 versus $13, plus they comped the last two bottles.
05-27-2016, 10:26 PM | #5 |
Picture me rollin'
308
Rep 1,130
05-28-2016, 06:54 AM | #6 |
Rep 3,071
My local dealer tops engine oil for free. Strange they charge you.
They will only top off when light comes on, plus it takes time waiting. At $450 and hour, a 20 minutes wait to save $7 is not productive, and they have given me two bottles free.
05-31-2016, 01:02 PM | #7 |
Rep 39
my car started eating a lot of oil
had bmw change injectors engine dried up oil within 1k miles of injector change.... no light went off...engine was dry...seized...bmw currently replacing. |
06-02-2016, 07:09 AM | #8 |
Rep 3,071
Car is now at dealer to investigate oil issue
06-03-2016, 07:10 AM | #10 |
Rep 3,071
"I ma also having to put a quarter every 200-300 miles, car only has done 15K, that's way too high been told. what could it be?"
The net is all over this issue. Some same poor break-in can allow oil to seep past thew rings and get burned in the engine. Other say it is due to expanding seals (intentional design) allow oil to seep or escape. My service tech said drive harder (presumably to get engine temps up). I am at 700 miles a quart, 200-300 a quart is way too high
06-04-2016, 11:13 AM | #11 | |
Rep 233
Drives: F90 M5 LCI - Aventurine Red
At this rate BMW should offer to replace your engine FOC. Which dealer do you use ? I am London based too !
F90 M5 LCI - Aventurine Red/Smoked White-E39 M5 - Modified ESS Supercharger Kit -E34 M5 1995 - Arctic Silver / Black Leather-
E30 M3 1987 - Diamond Black Metallic / Black Leather-996 Turbo - Lapis Blue/Savannah-VW Rallye Golf |
06-04-2016, 02:47 PM | #12 |
Rep 3,071
Just got my car back, and the report states, "normal oil usage is up to 1 quart every 750 miles."
Will be buying oil by the case at this rate!
06-09-2016, 11:18 AM | #13 |
Rep 156
Hi
I'm based in West London, got the car booked in HR owen |Park Royal. Not sure how good they are to investigate this issue. The car has been in 2 months ago same place for a repair/warranty job. The rate of oil consumption is excessive and certainly not a small issue, |
06-10-2016, 04:56 AM | #15 |
Rep 156
06-10-2016, 06:24 AM | #16 |
Rep 3,071
BMWNA: Because of their increased power output and torque, M engines have a maximum permissible oil consumption of 1.5 l/1000 km.
Your rate suggests a leak.
06-10-2016, 09:12 AM | #17 | |
Rep 233
Did you buy the car brand new ? If so which dealership ? There is no obvious evidence of an oil leak or oil burning with a smokey exhaust right ? You need to tell the service manager that you want them to carry out the official oil consumption test. (I think it involves actually draining and weighing the oil after driving a known distance, but could be wrong here). If it materialises it consumes more than permissible by BMW guidelines you need a new engine at BMW's cost.
06-11-2016, 11:29 AM | #18 |
Rep 3,071
IM6. It could be a bad seal allowing oil to pass when driving (under pressure), so you will; not see a leak.
Any smoke from the rear?
06-13-2016, 10:00 AM | #19 |
Rep 156
dropped off the car today at HR owen Park royal, they will start their proceedings tomorrow.
Havent seen any smoke from the rear while the engine is under load. A common question that keeps being asked. that would certainly point towards dodgy deals and rings etc. |
