      06-17-2016, 10:01 PM   #1
donesnake
Drives: 135i
WTB Performance steering wheel V1 CONTROL UNIT
I have one Performance wheel V1 without the other components, but the one i really need is the control unit, anyone here?
Thanks!
      06-23-2016, 05:18 AM   #2
Hg
Drives: e87 130i M
Thanks!
I am after the same shit
have you been able to find?
V2 fits the V1 perhaps?
      06-28-2016, 01:38 PM   #3
donesnake
Drives: 135i
Apparently not, i already asked another member that tried v2 unit and he told me it didn't worked for him
      06-29-2016, 02:34 AM   #4
Hg
Drives: e87 130i M
then there is only 1 way
getting the unit fabricated by copying from another control unit
what do you think?
      07-08-2016, 01:55 PM   #5
Downeaster1
BMW Master Tech
Downeaster1's Avatar
Drives: E30, E36, E82, E90, F10, F80
what do you think?
I don't need one per say, but I'm all for this. I have a working unit that I can possibly send out to get copied as the only way to get a new one is to buy the whole damn kit.
135is #502 of 586
BMW LED Performance Wheel | OEM FULL Carbon Fiber | E9X M3 Gauge Cluster | E9X Exterior Mirrors | E9X M3 Full Suspension | E9X M3 Diff | PT-CAN2 Enabled | Bilstiens | Michelin PSS's | NBT Navigation Retrofit with Touch Pad
      07-10-2016, 07:54 PM   #6
donesnake
Drives: 135i
Well if you can get a copy that would be awesome and i don't think we are the only ones looking for that control unit.
tell me if i can help
      07-20-2016, 02:56 AM   #7
Hg
Drives: e87 130i M
bmw manufactured this steering wheel till 2011, and how come they discontinued the part on 2012?
I escalated the issue to local dealers management, and guess what?
they confirmed that V2 control unit and harness will be ok for V1
now I will order the new parts (around 450 usd!) and will see what it turns out to be
if they dont match, then I will be a big issue for the dealer
      07-20-2016, 03:02 AM   #8
Hg
Drives: e87 130i M
by the way, I made a research for the fabrication
Engineering time will cost much more than new complete steering wheel as they say...
      08-04-2016, 05:37 PM   #9
donesnake
Drives: 135i
Alright dude, test it if it works, you will be helping a lot of people like us!
share the news once you know
      08-08-2016, 07:42 AM   #10
Hg
Drives: e87 130i M
will do so Senior
will keep you posted
hope it will work, fingers crossed!
      08-29-2016, 09:32 AM   #11
Hg
Drives: e87 130i M
YESSSSSSSSSSSSSSSSSSSSSS
It worked!!!
Yes, V2 control unit works for V1
Still have a problem tho: Everything works fine BUT the shift lights
same problem of Kevin here
http://www.1addicts.com/forums/showthread.php?t=1231283
Hope I can sort that too
should anyone need help, do let me know
      10-03-2016, 11:40 PM   #12
donesnake
Drives: 135i
THIS IS AWESOMEEEE!!!!!!
It worked!!!
      03-07-2017, 03:09 AM   #13
Hg
Drives: e87 130i M
have you tried to fit the V2 module to V1?
      03-08-2017, 05:42 PM   #14
Dat Aus
Drives: '08 135i
Sorry to threadjack but does anyone have a part number for the control module?
      03-09-2017, 04:45 AM   #15
Hg
Drives: e87 130i M
Part numbers,
- 61 12 2 212 796 - wire harness, Performance Steering Wheel
- 61 13 8 364 664 - Connector, 12 pol. female (socket), (Tyco 965776-1 B) (to PSW Control Unit) (A6 on BMW installation diagram)
- 61 13 8 364 646 - Covering cap, 12 pol. connector (Tyco 1-967415-1) (to PSW Control Unit)
- 61 35 0 444 602 - Control Unit, Performance Steering Wheel (PSW) (P-Lenkrad) ($139.45) (61 35 2 212 797 for V2)
- 61 13 8 373 575 - Connector, 2 pol. male (pin), (AMP 1-968654-1) (A5 on BMW installation diagram)
- 61 31 9 122 381 - Coil spring cartridge (Slip ring) (w/additional 3-wire cable from top)
- 61 13 6 954 518 - Connector, 12 pol. female (socket) (Tyco?) (to Coil spring cartridge) (replaces 61 13 6 954 516) (A7 on BMW installation diagram)
- 61 13 1 393 724 - Pin, female (socket), for 12 pol. and other connectors (for A3, A4, A5 and A7 on BMW installation diagram)
I home made the wire harness, and bought the control unit of V2 for my V1
it worked fine except the rev counter
it reads 10 times less than actual
Dat Aus117.50
RJ01989.50
      03-09-2017, 07:24 AM   #16
Dat Aus
Drives: '08 135i
Thanks for that. So there is a Performance steering wheel for sale locally but the seller says it does not come with the control module. How do I know if I need V1 or V2? And where would I be able to find one?
      03-09-2017, 08:14 AM   #17
Hg
Drives: e87 130i M
if the PSW is V2 then you need V2 control unit (61 35 2 212 797)
if the PSW is V1, then walk away
Dat Aus117.50
1addicts
