06-23-2016, 10:39 AM | #1 |
Rep 369
Brake pads don't bite
Stock Stoptech Trophy brakes don't bite at all cold, better when hot but not great. Anyone experience this with their pads? What's a decent brake pads that won't kill the rotor or my wallet
06-23-2016, 11:19 AM | #2 |
Rep 1,325
Are they bedded in properly? I'm guess this is for street use so pick a street pad like the stop tech street. Pointless to use race pads on the street
06-23-2016, 09:48 PM | #5 |
Stop the hate, get a V8
3853
Rep 8,625
BBKs don't feel like the stock system. The initial bite is typically less aggressive but it's more linear throughout the travel. My StopTech kit (with their Sport/Street Performance pads) feels like you are describing.
Pads do play a part in it, too. Some pad materials are not as "dense" and feel a bit softer. If you want to step up to a more aggressive street pad on that caliper, try the Ferodo DS2500 pads.
Now: 2017 Corvette Grand Sport, 2021 AMG C63 S sedan
Past: 2011.5 M3 sedan ZCP |
06-23-2016, 11:20 PM | #7 |
3853
Rep 8,625
I disagree. I've had them on two different cars, one of which previous had the StopTech pads. The DS2500 has a firm pedal feel.
06-23-2016, 11:53 PM | #8 |
Rep 9,034
The ST ceramic street pads SUCK BALLZ.
THe Street/Sport pads are a good compromise pad. I think the initial bite is a tiny bit less than stock but not that much off but they dust way less and are better on track.
Let me get this straight... You are swapping out parts designed by some of the top engineers in the world because some guys sponsored by a company told you it's "better??" But when you ask the same guy about tracking, "oh no, I have a kid now" or "I just detailed my car." or "i just got new tires."
06-24-2016, 07:50 AM | #9 |
Rep 369
I do not recall what the trophy kit came with but whatever they are they do not stop for crap cold. I have a very firm pedal but they don't work. Hot they start to get better but I haven't gotten them at track levels aside from the bed in procedure months ago.
OK I'll look into some of the ones suggested |
06-29-2016, 06:30 PM | #10 | |
Supreme Allied Commander
3893
Rep 54,602
Drives: F80 M3
06-29-2016, 09:59 PM | #11 |
Rep 8,077
Drives: 11 E90 M3 Individual
Did you wash the rotors in soap and hot water before installing? I've seen a couple of instances of people not doing this for some reason.
2018 F30 320iX Melbourne Red
2011 E90 M3 Monte Carlo Blue 2004 E46 M3 Imola Red 2000 E36/7 Z3 Steel Blue |
07-01-2016, 04:53 PM | #12 | |
3853
Rep 8,625
The old "Street Performance" pads are now just called the "Sport" pad. This is what StopTech includes with their BBKs. It's for street and mild track use. There is a new "Street" pad which wasn't available before.
07-01-2016, 05:14 PM | #13 |
Track Whore
542
Rep 1,640
OP: Did you install the pads and rotors together new? Is this a used kit?
You might need to remove the old pad layer from the rotors if this was a used kit. I typically use an electric sander with aggressive grit sandpaper for this. It might also be the temp range of your pads. Track/race pads need to be heated to work correctly, which is why they are not recommended for street use. |
